Rear passenger side suspension low
celica
Times I love the functionality of this car but as of late its issues after issues
Now the rear passenger suspension has been dropping over night
Start it up and go around the block to check it raises again
I've done some initial google search and seems to be a fault with age on air suspension possibly
Anyone else had this?
- rob
Re: Rear passenger side suspension low
I had exact same problem the dealer diagnosed a leaking left suspension air bag and replaced it three weeks later the right hand side went to
pcdee
[quote="rob"]
I'm suprised the dealer didn't replace both of them at the same time. They should be replaced in pairs.
Sent from my SM-G900F using Tapatalk
X5 E70 3.0D SE
- rob
As it was under auc they did eventually and some compressor
- rob
Here is a picture of the air bag leak from the video the dealership sent me
celica
Can't see the pic / video
Just had a look on eBay, do you know parts as some listed on there
celica
Found on realoem part number
37126790078 bmw
Mine is adaptive drive, I wander if any different in parts between adaptive drive or not
First google search with that part number brings up part at c£100
https://aerosus.co.uk/catalogsearch/res ... GwodkuENDA
37126790078 bmw
celica
celica
If it's one of those parts then not too pricey
Will find out how much from dealer
Wonder how long it takes for a competent mechanic
But here is how it looks
- rob
Picture won't upload
pcdee
[quote="celica"]
Got mine done 2years back at Mr Clutch for under £100 for both.
Took them under an hour.
X5 E70 3.0D SE
It happened to mine about 6 weeks ago. From memory, a replacement part from BMW was about 240 +VAT. I got an Arnott unit for half that from Europarts delivered to the workshop in an hour. It took my indy mechanic less than half an hour to fit and that included checking the other bag, compressor and pipe unions. Total cost - less than that for the BMW part. It's a straightforward process and the change does not affect the sensor that controls the variable height of the rear.
Arnott have a good You-tube video to show how it's done. https://www.youtube.com/watch?v=7WXxrI5QFdk
celica
[quote="pcdee"]
[quote="celica"]
£100 for both parts and labour!?
[quote="celica"]
