Wierd elec problems
- toonarmy
Wierd elec problems
These are ongoing issues with everybody I think but today did a bit of fishing and to my shock found the negative lead to the body was loose and had been arcing bad enough to melt the stud lead seamed tight at first but getting a good hold found it to be slack a must check for everyone I think cheers
X5 e53 3.0d 53 plate and Honda vtr1000 fun time
Re: Wierd elec problems
Definitely a wierd one. Sounds like it has been taken off in the past. Good advice.
[quote="toonarmy"]
[/quote]e
Brings back memories of when I had to do an engine transplant in my first ever motor ( Mini Van ) when I fitted the new engine in I forgot to attach the earth strap from the body to the engine. When I cranked it over it melted the accelerator cable, as that was the only metal link between the body's negative earth and the starter.
Hopefully finding tours loose may cure all your woes.
[/quote]e
- toonarmy
Well all seems good so far no glitches etc
RenoHuskerDu
As a general rule, the odder the symptoms are, the more I suspect a bad ground somewhere. I'm as old as dirt and have found bad grounds at the base of dozens of weird electrical gremlins. Move to Arizona and Bob's your uncle, no more rusty connections.
