Pre lci inner rear lights
ssrfr03
Post by ssrfr03 » Tue Mar 08, 2016 2:26 pm
My rear inner light has about 4 or 5 like tubes in it and the top 2 aren't lighting up is this a bulb or does it need replacing thanks
Re: Pre lci inner rear lights
Post by Graeme » Tue Mar 08, 2016 3:35 pm
The unit is a sealed LED device.  The most common problem with the older ones is caused by the gasket breaking down so letting water in that corrodes the unit and stops the lights working.  The unit has to be replaced completely but they do come with new gaskets that are supposed to be much longer lasting.  Mine had to be done about 2 years ago when they were 6 years old.  Cost roughly £100 per side depending on the current price for the units.  Fitting is  straightforward and quick so I had the local BMW body shop do the job for me.
Hope this helps,  Graeme
99ron
Post by 99ron » Tue Mar 08, 2016 4:32 pm
and pretty much what he was told here...
http://xdrivers.co.uk/forum/index.php/t ... 255.0.html
3.0SD E70 M Sport.
Z4MR E85
