ANOTHER battery issue
Post by Aaron_P85 » Mon Feb 22, 2016 7:29 pm
next morning 'BING' time/date need set again, and cranked over a little slower...but started first time...
I've unlocked the hidden menu and checked voltages
Idle: 14.9/15v
switch off: drops under to 12v within 60 seconds - illuminating the battery sign and shutting down near enough everything...
so with everything off I went on a 45 minute, non stop, motorway journey...turned the car off...waited circa 2 minutes with the ignition on but 'everthing' off and BING battery sign again.
no 'high drainage' signs and its an original BMW battery....perhaps the original? before I take it to the local Coopers...does this sound like a dying battery or something else?
I have used the search function, and can find each of my symptoms separately...but not together
Aaron
Aaron_P85
Re: ANOTHER battery issue
Post by Horizon » Mon Feb 22, 2016 9:26 pm
I would leave it on a trickle charge overnight and re monitor .
You havnt told us the age of the car, if it's got the original battery on it and it's 5 years old I would change it as a matter of preventative maintenance. If it's a BMW battery they are date stamped on the top of rhe terminals.
Aaron_P85
Post by celica » Tue Feb 23, 2016 7:57 am
celica
Post by Nine468 » Wed Feb 24, 2016 1:10 pm
Mine has just had to be replaced, i got a similar problem, dash reset, high drain messages.
Put on charge for 24hrs, then ok for about a week, but then back to dash reseting, so got a new battery fitted and coded , now all fine, BUT only after charging it up on the trickle charger overnight, It might have been on the shelf for a while...
BMW E70 X5 40D
Nine468
Post by celica » Wed Feb 24, 2016 9:38 pm
What messages did you have or was it just the clocks resetting
What trickle charger have you got, after reading here I'm looking for ctek for AGM
celica
Post by Aaron_P85 » Thu Feb 25, 2016 7:40 am
Bought Bosch S5 for £105 and Indy to code it in - £155 total.
I'm now looking to have the tarnished aluminium on the side steps painted all with my wheels in anthracite... Is the aluminium part just bonded on and pop the rubber grips out?
Aaron
Aaron_P85
Post by Nine468 » Thu Feb 25, 2016 10:30 am
My battery cost me £185 fully fitted and coded by my indie...
The trickle charger i have is one from Aldi, and it works just great, way cheaper than the Cteck ones...
BMW E70 X5 40D
Nine468
Post by celica » Thu Feb 25, 2016 11:43 am
I went for the above route. Standard battery and coded for something like £160-170
Found out my old one was AGM so had it upgraded and paid the difference due to the issues of increased battery discharge message, cost differential £70. So about £240 all in, but still having issues as mentioned
Maybe should have gone to Bmw if it was at £275 and paid the difference as if having the clocks reset and error message would have got BMW to re look
Not sure what Indy can offer next
celica
Aaron_P85
Post by BullyB » Tue Mar 08, 2016 2:50 pm
how do you do that?
BullyB
Post by celica » Tue Mar 08, 2016 6:11 pm
[quote="Aaron_P85"]
how do you do that?
Took me several attempts but this guide describes how
http://www.scoopz.com/m5board/E60_Hidde ... ctions.pdf
celica
Post by celica » Tue Mar 08, 2016 6:12 pm
NOW I'm getting the dash reset and high drainage message.....battery death iminent haha
I recommend going for an AGM battery if you have one already
I've been having issues as per my other thread
Hope it fixed itself
celica
Return to “Problems (E70 2nd-gen, 2007-2013)”
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
