Page 1 of 4
				F25/F26 Tyre thread
				Posted: Sat Feb 20, 2016 9:35 pm
				by Pinewood
				Being a different beast to the X5/X6...
What are your tyres of choice? (Runflats, normal , manufacturer, tyre pressures)
Let's have your views, observations and comments....
				Re: F25/F26 Tyre thread
				Posted: Sat Feb 20, 2016 9:47 pm
				by Pinewood
				I'm running a staggered setup,  which makes the car look great aesthetically, but not convinced it's the best setup for comfort.
The plan is to buy another wheelset (probably 18" non staggered) and shod with regular tyres initially.
				Posted: Mon Feb 22, 2016 8:29 pm
				by RodHB
				I have run flats on my F25 - mainly for peace of mind when my wife drives it on her own. We do have a space saver (emergency wheel kit) in the boot.
My winter set are normals. Gives a rougher but softer ride but hardly discernible from the run flats.
Perhaps the variable damping helps?
				Posted: Tue Feb 23, 2016 12:09 am
				by Pinewood
				Did it come with a skinny spare or did you purchase it after?
				Posted: Tue Feb 23, 2016 9:40 am
				by RodHB
				No I had it already from when I had an E61 and at that time was replacing run flats to normals.
It was a MSport with sports suspension and the run flats made for a very hard uncomfortable ride.
I'd replaced the rears with normals as they wore out but didn't get round to the fronts before I sold it.
I've had/got variable damper control on both my F25s, both with run flats and it's a much better ride though wether that's the cause I don't know?
				Posted: Tue Feb 23, 2016 11:52 am
				by Pinewood
				I changed all 4 tyres on my E60.  It was also a 530d M Sport and the ride was sublime on normal tyres.
				Posted: Tue Feb 23, 2016 11:55 am
				by Pinewood
				The variable damper control irons out the bumps which mine does occasionally .  I think that's more to do with runflats having very little "give" compared to normal tyres,  and not the M Sport suspension per say.  My bro-in-law has a C220 sports with a much firmer ride.
				Posted: Thu Feb 25, 2016 7:44 am
				by Pinewood
				What tyre pressure are you guys keeping front/rear on 19' alloys.
33 psi front
34 psi rear
At present, with me being the usual occupant and max 3 occupants on weekends. No luggage to speak of.
				Posted: Thu Feb 25, 2016 11:29 am
				by RodHB
				When I picked my car up they were set at 35 all round - I think they are supposed to be 32 front 35 rear?
				Posted: Thu Feb 25, 2016 1:10 pm
				by bluestreak56
				Standard run flats on my F26. All around 30psi at the moment and the tyre pressure sensor hasnt complained..
				Posted: Thu Feb 25, 2016 3:37 pm
				by Pinewood
				[quote="bluestreak56"]
you could pump them up to 20psi and set the TPMS - it wouldn't complain.
I would take another look at the handbook, C Pillar as that sounds a tad low, and you will wear the tyre shoulders out quickly
				Posted: Sat Feb 27, 2016 10:17 am
				by bluestreak56
				[quote="Pinewood"]
50psi seems excessive. However I will check the recommendations
				Posted: Sat Feb 27, 2016 2:45 pm
				by Pinewood
				I agree 50psi is excessive.  Without knowing your model,  i would respectably suggest 34f/36r
				Posted: Fri Mar 04, 2016 7:26 am
				by Pinewood
				This car is bringing out some OCD i didn't know i had.  I keep looking at the onboard tyre pressure display!  It's really hard to get fronts and rears to EXACTLY the same pressure as it's sibling
				Posted: Sat Mar 05, 2016 10:54 am
				by Pinewood
				Just had the following update from event tyres after i enquired about rft and normal rubber.
The price for your runflats     245/45R19 98Y PIRELLI PZERO BMW@ £188.82 INC VAT EACH
275/40R19 101Y PIRELLI PZERO BMW X3 *@ £204.78 INC VAT EACH
And your non runflats
 245/45R19 98Y PIRELLI PZERO@ £173.52 INC VAT EACH
275/40R19 101Y PIRELLI PZERO@ £179.44 INC VAT EACH
All prices include fitting and balancing. Anyone used them?
