just been having a play in the x5 getting used to all the goodies and there is a little button on the center dash that says max and for the love of god i cannot get it to work.
is there a special setting i need to follow?
max ventilation button not working
the shreksta
Re: max ventilation button not working
It should put the blowers onto maximum.
the shreksta
do you know if its a separate fuse?
the shreksta
could it be something to do with the final stage resistor?
Pass. I have never suffered an FSR fault so I can't help with what it actually does. If the system is working normally elsewhere then possibly not. It could just as easily be a button fault but it's part of a single control panel AFAIK and not individually replaceable.
the shreksta
Ok, I'm not really that fussed to be honest as all the blowers/Air con work which is the main thing. If I see a cheap second hand control panel I may swap it over to see if that cures it
