good trustworthy specialist in the hinckley/Midlands area please
the shreksta
I am requiring a full transmission service (diffs/transfer/autobox)
I need a good specialist in the midlands who knows the correct method of changing the gear oil as it has to be done at a certain temperature.
Any recommendations guys? A quick Google brings up auto-teknik in Lutterworth and the independent bmw specialist in hinckley ran by Paul bramley.
Thx guys
Thx guys
themoog
Re: good trustworthy specialist in the hinckley/Midlands area please
Do it yourself. Simple. Dont worry about the temperature- when doing it if the sump is hot to touch then its about right. I did mine for about £110. I worried about it beforehand but researched and there are loads of how to's on the internet.
Remember that the trans fluid has to be drained at least twice so that the torque convertor is refreshed.
My method:-
Drive car up on 2 pving slabs under each wheel to get it level.
Loosen fill plug then drain sump.
Remove sump, swap filter, clean magnets then replace.
Refill, fit drain plug and run engine till sump is hot (circa 13min) and check level.
Drive for a few days then drain and refill.
Messy but easy.
My method:-
Messy but easy.
jagr
I have never used them but these are supposed to be good:
Barry Deadman
Auto Mechanical Services
76 Nedham Street
Leicester
LE2 0HA
0116-253 0770
Barry Deadman
76 Nedham Street
Leicester
LE2 0HA
0116-253 0770
2011 BMW X3 30d M Sport
- warsi
- Contact:
I've been using BM Euroservice in Wolverhampton for all non-dealer work on my various BMWs for last 10+ yrs now. Mark and Paul are the main chaps who run it and provide a very professional service. I always found the work done to be of a high standard.
Not sure if they do transmission service though, never asked or have it done.
2002 325i Sport Black/Beige
1998 318iS Black/Beige
the shreksta
[quote="themoog"]
My method:-
Messy but easy.
where did you buy all the stuff needed (oil/filter/sump/mechatronics sleeve)
i was led to believe that it had to be at a certain temp and then ran through the gears in a certain sequence
My method:-
Messy but easy.
The sequence and temps are in the manual I linked you to. A web search should reveal the parts for the ZF box.
There is a thread on here about the oil types from a couple of years back if memory serves, with tips on what oils you should/should not use.
the shreksta
its just that im really struggling to find somebody to do it, ive rang a few places and asked about the procedure that needed to be followed and a few have said it sounds like a load of rubbish lol
perhaps i should believe in the old saying.............if its not broke-dont fix it
X5-D-Sport
Trustworthy Specialist....
My God Man.... the word "Trustworthy" is a tough one these days...
suggestion : if there is a "Trustworthy" one within 50 miles, then go there..
a vehicle is only as reliable as the last person to wave a spanner near it !!
So, if some one here knows of a decent garage ANYWHERE, let alone near Birmingham, then go there me thinks.
There are a few good garages about, so word of mouth here is where you will find them I recon.
Mpower
You have a point mate!
the shreksta
im tempted to go here for a tranny service
http://www.theautomaticgearboxcompany.co.uk/
about 40 miles from me to derby
anybody used them?
anybody used them?
Had mine done at their place in Rochdale. £170 + VAT
I always say it's better to use a gearbox specialist over an indie for gearbox services, as they know these commonly used boxes inside out.
the shreksta
[quote="Horizon"]
the price list is £245 for a service
did they follow the procedure and replace the mechatronics sleeve?
[quote="the shreksta"]
[quote="Horizon"]
[/quote] they replaced. Sel where some cable came out of the box, which is a known point at which can leak.
Is this what you re referring too
Mine was £210 inc vat and that was 3/4 years ago, so similar money.
[quote="Horizon"]
the shreksta
[quote="Horizon"]
[quote="Horizon"]
hhhmm not sure, ive seen it in service kits, it looks like a little black pipe/tube
did they do the procedure?
[quote="Horizon"]
They had a pile of pile of ZF boxes on their benches which they were overhauling. These guys can rebuild our boxes in their sleep.
A service shouldn't be a problem.
