Smell
Stuart
Smell
Post by Stuart » Mon Jan 18, 2016 12:34 pm
When I'm stood in traffic I keep getting a burning smell 30i petrol auto 2005  , there are not any leaks or loosing any fluid ect but the smell is very strong , any ideas ? Thanks
Steamyrotter
Re: Smell
Post by Steamyrotter » Mon Jan 18, 2016 1:06 pm
I'd check the exhaust manifold isnt leaking first..
Common fault on the 3.0d, but not sure if its the same on the petrol??
Then all connections / pipes etc around the exhaust system
Slick
Re: Smell
Post by Slick » Mon Jan 18, 2016 5:32 pm
I suspect a leaking cam cover gasket......dripping slightly onto the hot exhaust manifold
Jaguar F type
X5 4.4 facelift
Vauxhall Vectra diesel  daily driver
Stuart
Re: Smell
Post by Stuart » Mon Jan 18, 2016 8:59 pm
Ok will double check for leaks
zabe_1
Re: Smell
Post by zabe_1 » Wed Jan 20, 2016 6:51 pm
I had the same issue, it was exhaust manifold ( a very common issue with these cars).
Does your exhaust blow at al, if not, if you sit in one place with the car running, do you smell a gas smell?
If you do need to replace the exhaust manifold, you can pick up a cast iron one on ebay for £70 and get someone to fit it for you (I got someone to do it for £230). So £300 all in.
If you go oem route, some guy was planning on charging me £1k all in. MASSSive difference since I replaced it and NO smell at all
X5-D-Sport
Re: Smell
Post by X5-D-Sport » Thu Jan 21, 2016 12:17 am
I have a manifold leak... still awaiting a place yo do thw job on my X5 where I can start the job & not get frozen or drenched doing the job... i got a loud turbo whistle & my X5 smells awfull...
Oh to have a decent workshop again....
Hoping I get a performance & economy increase when the turbo is spinning properly again one day...
I got all the parts, just gotta find some where to do the job...
