Transfer Case, Automatic and Diff Oil change
jagr
Hi All,
I went to my local indy today too get my fluids changed.
Transfer Case
Automatic gearbox
Both diffs
I was quoted £300 when I made the booking early last month but today was charged £444 due to a mix up with my gearbox being a 'Mechantronic' system.
This has now concerned me as I had an Audi A4 (1.9tdi A4 '54) that had to have it's mechatronic gearbox replaced are the BMW ones more reliable?
Transfer Case
Automatic gearbox
Both diffs
2011 BMW X3 30d M Sport
- kkx5
Re: Transfer Case, Automatic and Diff Oil change
Audi- multitronic gearbox never used on any BMW...
The 'Mechatronic' unit is the control system fitted to the 6-sp box. It's what controls the box hydraulics etc.
Big A
Was the original price of £300 including the oils?
Was considering getting my transmission oils done, but that seems a hefty price to change them. Got the gearbox and diff oil done on my old 1 series and it was only £50 to do and I provided the oil.
I would certainly hope at that price it also included a new filter too!
jagr
[quote="Big A"]
Yes
I was quoted:
Gearbox oil change £60.00+ VAT for the oil and £60.00+
VAT for labour and re-sets.
Transfer case oil change £40.00+ VAT for the oil and
£30.00+ VAT for the labour.
Differential oil £30.00+ VAT for the oil and £30.00+ VAT for the labour.
When I went to pay:
Gearbox oil was £120+ VAT and £60+ VAT labour
Transfer case was as quoted £70+ VAT
Diff Oil was x2 £60+ VAT oil and £60+ VAT labour
Total £444
From my receipt and quote it doesn't look like I had the filter changed
Yes
I was quoted:
When I went to pay:
Total £444
>:( probably didn't remove the pan! >:(
Big A
Do you know what oil/grade they used in your diff and transfer box?
Mine is a manual box so our gearboxes are different, but I assume the transfer box and diff will be the same throughout the E83's?
Also is the filter located on the diff?
jagr
[quote="Big A"]
All oils were from BMW.
I believe the filter is in the gearbox.
When they did my old X3 that was manual they did not recommend a gearbox oil change.
Big A
I was told the same with my old 1 series about the gearbox not needing done as it was "sealed for life", but after speaking to a couple of mechanics they said that best doing the box at the same time as the diff and the "sealed for life" is a lot of rubbish. After getting it done, the gearchange was a bit smoother mind you. I also got my oils from Amazon and saved a fair bit.
The 'Sealed for Life' refers to BMWs 'life' as they see it.......which is to the end of the warranty only, or 3 years! It's a bad joke and not what most owners would interpret it as meaning. >:(
