Check brake lights
andym3
Check brake lights
Post by andym3 » Mon Jan 11, 2016 8:08 pm
My check brake lights keeps coming on, but have checked the lights & they are working fine!
Any ideas?  :-[
Re: Check brake lights
Post by X5Sport » Mon Jan 11, 2016 8:19 pm
Intermittent bad connection on the bulb holder most likely.  The bulb check test is only a short pulse and may be highlighting a poor connection.
andym3
Post by andym3 » Mon Jan 11, 2016 8:49 pm
Take them off & give them a clean then you recon?
storminmike
Post by storminmike » Mon Jan 11, 2016 8:52 pm
Agreed.....look at the brake/tail light holder. Have you taken it out, given it a teensy tweak on the holder ears and put it back?
A quick dab with fine wet n dry on the back of the lamp...or worst case take the light out completely and look for pits where the holders make contact. Bit of fine sanding or filling with solder
andym3
Post by andym3 » Mon Jan 11, 2016 9:02 pm
[quote="storminmike"]
Ok thanks, I'll hopefully find time over the weekend to sort it out!  8)
storminmike
Post by storminmike » Mon Jan 11, 2016 9:04 pm
[quote="andym3"]
Don't drop the nuts!!!!!!!!!
andym3
Post by andym3 » Mon Jan 11, 2016 9:16 pm
:)) ok will try not to!  ;)
andym3
Post by andym3 » Tue Jan 12, 2016 8:13 pm
Found the problem & now sorted! Thanks for the advice all!  8)
Post by X5Sport » Wed Jan 13, 2016 5:04 pm
Nice bit of insulation you have there..... :(
andym3
Post by andym3 » Wed Jan 13, 2016 8:47 pm
Yeah not sure why it went like that as the other two bulb holes were fine no rust! Anyway cleaned it up with a wire brush & re positioned the seal & now all good!  8)
Steamyrotter
Post by Steamyrotter » Wed Jan 13, 2016 11:53 pm
That looks about normal for an E53!!
Mine appear to have rusted right through!!
andym3
Post by andym3 » Thu Jan 14, 2016 9:36 am
Is weird how they rust like that when that part is not open to the elements! :-[
storminmike
Post by storminmike » Thu Jan 14, 2016 9:41 pm
Have you been imitating James Bond under water
andym3
Post by andym3 » Thu Jan 14, 2016 10:47 pm
How did you know?  :))
Is weird though as the other two bulb holes on the same light are rust free! It was literally the brake light hole!  :-[
