My new car came with cycle rack prep which on first view looks like a tow bar bracket without the ball any clues as to the difference
It also has 13 pin electrics (swing down)
X1 cycle rack prep v tow bar prepare
- allforus
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
Re: X1 cycle rack prep v tow bar prepare
No swan neck tow ball in the boot floor? I know the cycle rack prep was an option and I suppose it might use a standard towing bracket? The electrics would be 13-pin for a number plate/lighting bar.
If it is a full towing bracket and there's no swan neck then see if PF Jones can supply. It is most likely a Westphalia bracket as that is what is used on the other 'X' cars.
[quote="allforus"]
I would have thought if you can fit a standard tow ball to the bracket it would be very dangerous if it wasn't designed to take the weight of a trailer/ caravan.
On OEM fitted towbars , isn't there a sticker inside the boot , which states the towing capacity of the bar fitted?
sid10
Hi we have a towbar factory fitted , the attachment is normally in a bag in the boot ! They also did a bike prep kit which was just the lighting unit that you connected your bumper mounted bike rack too . This was mounted via the towing bracket eyelets in the rear bumper , two poles on the bike carrier screwed in the eyelets using a large Allen key . Check if your car has two towing eyelets as I was sure the new cars only had one ?
- allforus
Hi the tow bar looks like the main mounting area of the x5 factory fitted bar need to check with the dealer see what they say
But it certainly looks like a cheap way of getting the tow bracket factory fitted as it was only a£160 is option I think including the electrics
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
[quote="Horizon"]
Should be, but it came in the pack of things to be put on by the Dealer at PDI. Mine was handed to me when I took delivery - so I could put it where I wanted! It went in the correct place in the boot.
Never anthropomorphise computers. They hate that.- allforus
Took a close look at bar today it's a witter with detachable tow ball minus the tow ball but should be easy to get one I guess
No stickers insight though
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
- allforus
Confirmed with the dealer today that there is only one towing mounting arrangement it's the ball that's different the one for the cycle prep has a pin through the ball and is £210 and marked not for towing the other is £150
Little strange set up but guess that's BMW for you
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
