I have inherited a screeching noise from the Vee-belt that goes around the Alternator, Water-pump & Power Steering, initially I could not find any reason why the belt was making such a noise, but after taking off the underside pan and further investigation I found that x2 of the water cooled alternator mounting bolts were first thought to be missing, but on further investigation it was found that the x2 bolts had snapped off. I’ve managed to get the two broken studs out but now have a greater PROBLEM– I have now found out that the bolts (M6 x 35mm – Z1, Part No. 11121731208) are not a stocked item and have to be ordered from Germany and will take 7-10 days “normally”, but as it’s the “festive season” (Ba Hum Bug, NOT LOL!) it’s more than likely take “considerably longer”. And for whatever reason, (in today’s technological environment) I cannot order them to be delivered to a UK dealership via an overnight courier?? ONE STEP FORWARD. TWO STEPS BACK
So Question(s):
1. Going by the location (see attached photo) of the two snapped off bolts and a third that was bent, is this an historic design fault of the mounting bolts geometry?
2. Does anyone know where I am able to get hold of x6 off of the M6 x 35mm – Z1 bolts?
OR
3. Does anyone know what grade the bolts are so I can get the equivalent grade of bolts to fit?
4. What the correct torque setting is for the mounting bolts when tightening them back down?
All assistance greatly appreciated to get Betsy back on the road asap, (it's going to be a Very Sad Christmas :xmassad: for her otherwise)?
