Radiator flaps motor.
DaveR
Post by DaveR » Fri Dec 04, 2015 7:45 pm
Hi guys,
Do you know where I can pick up the motor which operates the radiator flaps apart from BMW? My one has been found faulty and the so called warranty company ( Warranty Wise ) won't replace it.
Cheers,
David
2011 X5 30d Msport.
Re: Radiator flaps motor.
Post by X5Sport » Fri Dec 04, 2015 7:47 pm
Have a look on Realoem for the part number and try fleabay.  Might be a Dealer only part.  It's most likely been classed as a wear and tear item so most likely exempted from the warranty.  Seems a bit harsh though!
