Head unit looks interesting
VanHaydn
Post by VanHaydn » Tue Dec 01, 2015 8:28 am
G-Day
been looking for a aftermarket headunit and trolled this site extensively and found pretty much everything th eUK had to offer except this one...which of coure I like , 2 prices one 70 quid cheaper as its in Hong Kong and subject to pocket ram raiding by Tax munky's, and one for 300 available locally so they had a make offer button and did that so we see here it is
http://www.ebay.co.uk/itm/151874890526
thanx to whomever posted the fix for putting the part that displays the dash editing part into the glovebox..shall be doing that if this unit will not do what it claims..we shall see. no fuss if it doesnt ther is plan B
cheers
HaydnImage
sleepyfolk
Re: Head unit looks interesting
Post by sleepyfolk » Wed Dec 02, 2015 11:26 pm
Does look interesting, keep us posted!
Mercedes CLK 320
Audi A6 Quattro 2.4
X5-D-Sport
Post by X5-D-Sport » Thu Dec 03, 2015 1:15 pm
Done the read-up on this....
Sounds & looks fab... and a direct fit for the junk in my dash currently & I can blue-tooth music from my galaxy fone too... + SD card input, & communicates with everything - even the steering wheel controls & will talk to your fone for calls also... FABBO...
As a comparison - to repair/update my current 11 yr old unit... it would cost £200 for the new maps from BMW, £140 to repair my existing dodgy screen on my Nav display, and it would still be out-dated shiiite afterwards...
This is gonna be Grants' Christmas present to himself.....Yay...  :-)
Post by X5Sport » Thu Dec 03, 2015 5:29 pm
:D  :xmasgrin:
I bought a Garmin Nüvi 3598 instead.....about the price of the OEM map discs.
VanHaydn
Post by VanHaydn » Thu Dec 03, 2015 7:18 pm
my iphone tom tom is excellent so will be running that back to back until i have the trust issues sorted out
mattyp
Post by mattyp » Fri Dec 04, 2015 10:05 pm
Have you fitted this yet?
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 3.0d Current Car
Steamyrotter
Post by Steamyrotter » Fri Dec 04, 2015 10:41 pm
Then you can let me have your old unit????
Slick
Post by Slick » Sat Dec 05, 2015 11:48 am
I'm sure I've seen this unit in a  X5 and it doesnt quite fit.......check out the lower corners....they'er square while the OEM unit has rounded lower corners and the dash is moulded to suit
Jaguar F type
X5 4.4 facelift
Vauxhall Vectra diesel  daily driver
yes_its_neil
Post by yes_its_neil » Sun Jan 31, 2016 10:42 pm
Hi, I fitted an earlier model of this unit to my X5 about 12 months ago. Does involve some ruthless cutting of the factory frame to get the unit to fit. It works pretty well, though my voice quality heard by callers is crap. I have experimented with external microphones but still poor. Base memory is a limiting factor for app installation, I am frequently juggling apps to perform updates. This may have been improved on the current unit. The reversing camera function is good, I'd suggest running cable in while you have the dash apart, even if not connecting it initially. I have fitted a 4G USB modem in the glove compartment and the unit works over wifi to that. The supplied navigation program is good (IGO), though I usually use google maps as I am online. When out of mobile coverage I use IGO.
I re-installed my MID in the left hand rear compartment. I do not have factory navigation or the cd changer and the MID fits perfectly in the existing empty frame.
storminmike
Post by storminmike » Mon Feb 01, 2016 7:36 pm
Some listings say HD C+EU MAP and some say HD A+EU MAP
What's that all about  C or A?
chubbs
Post by chubbs » Sun Mar 06, 2016 6:48 pm
Can anyone tell me the difference between the unit described by the OP and this one, which is £100 cheaper?...
http://www.ebay.co.uk/itm/BMW-X5-E53-7- ... Swv-NWX9AK
Waka
Post by Waka » Mon Mar 14, 2016 4:12 pm
OPs is Android based and the one you linked to doesn't say - so I'm guessing Windows based  :puke:
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
chubbs
Post by chubbs » Tue Mar 15, 2016 8:14 am
[quote="Waka"]
Thanks for this. Not being a software expert I'm guessing your emoji means you don't recommend Windows-based for a car head unit? Why?
Waka
Post by Waka » Tue Mar 15, 2016 10:32 am
The windows one will probably be fine (I don't have either) - but as a geek I like to tinker with stuff  :P and the Android one will be much more flexible for that.
And this website is quite useful for info if you're that way inclined!
http://forum.xda-developers.com/android-auto
Intravenous de milo
Post by Intravenous de milo » Wed May 25, 2016 12:15 am
i have the xtrons but with android lolipop os. only just fitted it as a temp fix, i've got to install crossovers and tidy thw wiring. everything seems to work ok with the exception of the steering controls which i put down to ripping out the dsp and other bits.
it cost me £165 but had a bashed gps input, this was an easy fix.
