The X recently lost all boost and I could do with some advice before biting the bullet and taking it in the local indy.
Not getting any smoke under acceleration and there is suction on the pipe coming from the vacuum control thingy which I'm told should mean that the turbo is working correctly?
I have checked all hoses going to and from the intercooler and all appear to be intact and connected properly but there are some which are hard to reach so I can't totally rule this out as being the problem.
There is a loud wooshing sound coming from behind the dash under acceleration when the turbo should be kicking in so not sure if this will indicate anything?
Any advice will be very much appreciated.
