???Does my X5 have swirl flaps???
Posted: Thu Nov 05, 2015 1:06 pm
by Keetybwoy
Hi,
I have a 2005 X5 3.0d and have been told conflicting info with regard to it having and not having swirl flaps.
My brother in law has a '55 plate X3 3.0d and his has them which he's blanked off, however I have been told X3's do have them and my X5 does not.
Can anyone shed some light on this please.
Cheers.
Re: ???Does my X5 have swirl flaps???
Posted: Thu Nov 05, 2015 2:37 pm
by Merida
Not sure about earlier, pre-facelift models but the 05' X5 certainly doesn't have them
Posted: Thu Nov 05, 2015 3:07 pm
by Denis O
Do a search on here.
No e53, whether pre or post facelift, has been found to have flaps.
Posted: Thu Nov 05, 2015 7:58 pm
As above.....never fitted to the E53. Later models have them.
Posted: Fri Nov 06, 2015 4:44 pm
by Keetybwoy
Hey everyone,
I'm grateful for your feedback.
I did do a search but found them a bit hit and miss but from your replies and advise already received, I can pretty much say my X5 doesn't have them.
I also have a 2008 335d msport coupe which I am blanking them off on next week and would have done them together, so you've saved me some beer drinking time
Very much appreciated, thanks.
Posted: Fri Nov 06, 2015 6:04 pm
by chelsea
yer might want to blank the egr valve off tho pal.
Posted: Tue Nov 10, 2015 1:31 pm
by Keetybwoy
Hi Chelsea,
Do you mean my X5, 3 series or both, that I need to blank off the EGR valve mate?
Cheers,
Posted: Tue Nov 10, 2015 4:58 pm
by chelsea
[quote="Keetybwoy"]
Hi Chelsea,
Cheers,
Hi m8, the X5 EGR valve, saves cacking the inlet manifold up
Posted: Wed Nov 11, 2015 6:21 am
by Keetybwoy
Hi Chelsea,
Where can I buy the EGR blank mate?
Cheers,
Posted: Thu Nov 12, 2015 6:21 pm
by chelsea
[quote="Keetybwoy"]
Hi Chelsea,
Cheers,
either ebay or make yer own for nothing
Posted: Thu Nov 12, 2015 6:54 pm
by Horizon
If you take it off, clean it with carb cleaner, refit it to the engine , then just blank off the vacuum pipe it will not open, so does the same job as blanking it. Future MOT, may require checking the valve as they did with DPF's
Edit : it is also illegal to interfere with emission control systems on cars. Beware
