Evening XDrivers,
I have recently had a problem with my E53, the tyre pressure monitoring / RFT light came on Sunday afternoon after a good run. I checked all my tyres and they all seem to be around 30 PSI – and fairly consistent with each other. I plan to reset the system tonight and check whether the light comes back on, but I was wondering if anyone had any ideas as to what this could be? The previous owner to the car had 3 new tyres of a different brand fitted around 4 months ago, could it be that the one remaining tyre is the anomaly?
Jack.
Tyre Pressure Monitoring / RFT light.
dubwud
Current: 2005 X5 3.0d Sport
Past (starting with the most recent): 2008 E90 335d M-Sport, 2007 E90 335d M-Sport.
- kkx5
dubwud
Re: Tyre Pressure Monitoring / RFT light.
Thanks for the direct response.
- CondorX5
The tyre pressure light can sometimes come on quite randomly - in most X5s of this age, it works on a rolling radius principle so can be quite sensitive to different tyre makes on each corner or pressures which go a bit low. The 4.6is I think has a different system with battery driven monitors in the tyre caps on each wheel.
Merida
The last time I hooked up the caravan my light came on, guess the extra weight on the rear upset it!
