new owner e70 30d
Gerosean
new owner e70 30d
Post by Gerosean » Mon Oct 12, 2015 8:03 pm
Hi all new here have just purchased a 2012 e70 se 30d 27k miles. I collect it tomorrow was looking for anyone with experience on a engine remap for this model i have read a couple of the stories on here about it and am keen to get it done.
any feed back good and bad would be great.
also anything i should be keeping a eye on for this model
cheers
gmc15
Re: new owner e70 30d
Post by gmc15 » Mon Oct 12, 2015 8:28 pm
Hi and welcome :) Be sure to post some pics when you get the car :camera:
x6 M50d
Post by X5Sport » Mon Oct 12, 2015 9:21 pm
Interesting article in the motoring press today.  Remapping invalidates your insurance unless you tell them - and apparently there is a legal requirement to do so.  Given that a serious accident could result in an forensic check of your map against the factory recorded map you might have a future issue.
There might be a wider fallout of the VW scandal than was expected with new tests (difficult to see that being applied retrospectively) looking to spot emissions issues - including those resulting from remaps.  At present the access to the OBD2 ports isn't part of the MOT checks, but who's to say what might happen at the next update to that?
If the remap changes the emissions of the vehicle then there is also a potential issue with the vehicle type approval and emission certification.  Remapped cars may need SVAs!  That could mean a simple forensic checksum validation by say the Police/VSA and a cross check would immediately pick it up.  We already know that the BMW servers are capable of wiping a remap as soon as they spot it, simple given codes called checksums are loaded in areas that remappers can't get at.  If the checksum differs then the system assumes a fault condition and reloads the OEM map.
VW may be the trigger for all sorts of unintended consequences.  Be interesting to see how this develops.  It can only get worse for the humble motorist.  It's getting harder and harder to do anything these days. :(
Post by X5Sport » Tue Oct 13, 2015 5:17 pm
Sorry no.....I wasn't at home and can't remember how I got to it :-[
Gerosean
Post by Gerosean » Tue Oct 13, 2015 5:32 pm
Ok so I picked up the car and seems to be in great condition the only thing i have noticed is that there is some corrosion around the center caps on the rims.  As the car is still under new car warranty for a month I am going to try to get bmw to replace them under warranty.
Is there anything that i should be looking at whilst its still under warranty
I will post some picks soon
thanks for any info in advance
Gerosean
Post by Gerosean » Tue Oct 13, 2015 10:33 pm
both the caps and the rims its tiny but i figure its only going to get worse.
