N/S/R indicator not working
Jamie_E53
Morning all. My car has recently developed a problem whereby the nsr indicator isn't working, as per rapid click/flash while indicating. I initially thought it was a bulb so bought one to replace it with, this never cured it and the original bulb is fine. I have switched the holder to the other side and it works there fine so rules that out. Is there any common or obvious faults I should be looking for, I'm about to remove the cluster and see if it's broken anywhere though I doubt that to be the case. Any help greatly appreciated.
- pvr
Re: N/S/R indicator not working
Often there is corrosion on the contacts. Clean those off first and see if that makes the contact again.
Jamie_E53
Thanks will see how that goes
- CondorX5
The rear clusters do go faulty - poor contacts generally at fault with corrosion. i have had one cluster replaced under warranty and the other side is playing up so likely changed soon as well. Hopefully its just a case of cleaning the contacts.
Agree with pvr and Consor.....
Can be improved without cluster removal but better access by removal (sockets required & be careful not to lose bolts into recesses). Sandpaper, wire brush or other abrasive will sort issues hopefully.
Not a fault you must understand - one of a number of small characteristics
Jamie_E53
Thanks for that guys, it was that afterallafter all. Quick clean and a rub with some sand paper and it's all working again.
Glad sorted - thanks for update
