Got in the Car this morning and saw a puddle in the passenger foot well.
Any ideas where it could come from?
Leak
Nat
Re: Leak
Ooooo , we all love a mystery leak.
Sunroof, ( Blocked tubes that run down the windscreen pillars ) , Scuttle panel blocked ( its a very large area ) , worn/torn door seals , torn/shrunk door moisture barriers ( anyone had the door trim off recently ) are places to start. My money is the scuttle panel cavity.............
If there is antifreeze with it could be your heater matrix/valves/pipes.
Ive had great fun over the years finding these leaks.
Good luck
Nat
Good luck
Nat
pcdee
Re: Leak
Update......
I checked the drain holes by the sunroof and they are not clogged. I tested the driver side just to see where it should exit the car.
So then I try the passenger side, the water just sits there, I checked under the car and there are just a couple of drops dropping slowly.
Could I get some compressed air in a can blow it through?
X5 E70 3.0D SE
- stevox5
Re: Leak
Hi there
Best thing to do is remove the inner A pillar trim (1 torx bolt under the airbag badge in the pillar trim)
You will then see the rubber drain tube running down the pillar into a metal tube just above the level of the dash, pull the rubber tube out and blow compressed air down the metal tube to clear the blockage at the bottom.
I did one last week and it was leaking so bad it ran water into the lamp control module that's mounted int the kick panel below the glove box , worth pulling that trim off and checking that control unit is dry.
Easy enough job
Good luck
Easy enough job
Good luck
