				Headlight Washer fault
				Posted: Wed Sep 16, 2015 2:53 pm
				by BigGX5
				So as the title says, my headlight washers are staying out every time I scoosh my lights. They pop up and scoosh but don't go down. I have to push then down. No amount of WD40 has made the situation better.
Any thoughts on a fix?????
				Re: Headlight Washer fault
				Posted: Wed Sep 16, 2015 5:59 pm
				Usually that means 'replace'.
Avoid WD40 on plastics as it can makes things worse.  Silicon or ceramic lubes only.
				Posted: Fri Sep 25, 2015 11:42 am
				by UrbanFlow
				I have the same problem on my 2007 E70.
Tried WD-40 - didn't work.
Used a silicon lubricant I got with my Arai crash helmet and it worked all summer - but they have just started sticking again.
What's weird is that they only need a light push and they whizz back in.
Might try the silicon lube again.
				Posted: Thu Nov 24, 2016 5:48 pm
				by Nictrix
				Sorry for dragging up an old topic but has anybody fixed their headlight washers after they have been sticking?
One of mine on the X6 is sometimes sitting out a bit after use and wondered if the only option is spraying with a lube.
As with the above, it doesnt take much to push it back in and as I understand it is a spring that brings it back into place, so what is it that goes wrong? Does the spring lose its tension?
Can these be removed and repaired or stripped and cleaned properly?
I think I saw they are around £70 each to replace so would rather try and fix the ones that are on it first.
				Posted: Thu Nov 24, 2016 5:51 pm
				If you do lube, only use a silicon one to avoid damaging the plastics.  Never seen one stripped and repaired.
Mine are 6 years old now and (at present) fine.
				Posted: Fri Dec 02, 2016 6:44 am
				by ssrfr03
				There is a video on you tube on how to strip these down it under bmw headlamp washer fix E90 show you how to take one apart
				Posted: Sun Dec 04, 2016 2:28 pm
				by bladerunner
				Are the Headlight washers visible from the driver seat when they washing the headlights? On my old E53 i knew when the washers were doing their thing but i can't see any fluid being squirted on my lights on my E70, I am not even sure they are popping up.
				Posted: Sun Dec 04, 2016 3:06 pm
				by Nictrix
				You can see the spray mist over the front of the bonnet when they have been activated.
				Posted: Tue Dec 06, 2016 12:28 pm
				by bladerunner
				[quote="Nictrix"]
I don't see any spray over bonnet so i am assuming they do not work, Time to think about delving into the hidden fuse box me thinks.
				Posted: Tue Dec 06, 2016 6:54 pm
				Spray should occur every couple of times or so as long as the lights are on.  Should run twice - they do on my X6
