Hi there,
I am looking to purchase a 2006 3.0d sport. However, upon asking if the air con functions as it should, the owner informed me that it appeared to take a while before icy cold air started to pump out. He indicated warm air was coming out, but it simply took a few minutes before it was icy cold. Once cold, he did say that it was very cold and remained cold.
I have searched through here, but couldn’t find any info. The X5 is unfamiliar to me, as my main experience is with older 3 series and 5’s. I am guessing this slowness to emit cold air indicates a fault of some description.
If some kind person could give me an idea if the air should blow cold almost instantaneously, I would be very grateful. Also if it is a fault with the air system, I just wondered if any of you guys have come across this issue before.
Kind regards
Stu
Aircon slow to kick out icy cold air
- Insight G40
Re: Aircon slow to kick out icy cold air
I've got a late 2006 3.0D Sport and it takes a minute to get really cold.
It works as it should after that, and I just put it down to the compressor taking time to kick.
E53 Sept 2006 3.0D Sport
TimX5
I had to fit a new pusher fan as the air con didn't operate properly until moving, fairly common fault.
Could just need the gas level topping up. I did mine with the Halfords DIY kit. It's about £50 and has done three cars so far. Takes about 5 mins to check, test and recharge if low.
Their gauge kit will tell you if the pressure is low. The system can lose around 15% a year, more if not used regularly - which it should be stop compressor seal damage.
max_gain
Many thanks for all your helpful comments.
I have heard of pusher fan issues with regards to other things. In this instance, could the fan be running slow or just lazy to get going.
The fan just runs if the system is on. The fan speed is determined by the external temp and your settings. It depends upon just how long it takes to get cold. If more than a couple of minutes when set to 16C then the gas level is worth a check. On my E53 I found it was taking a bit longer than ?I thought it should. The fan was running and a gas check found the pressure was right at the bottom of the 'green' range so I added a bit to take it back up to the right range and it performed much better
The kits are simple to use as all you do is run the engine for a couple of minutes with the a/c at its lowest setting and plug the gauge onto the low pressure point and it will show you if the system pressure is within the correct range. If not you squeeze the trigger on the top up cylinder until it's in range and jobs a good un
If it's a fan issue then a replacement is pretty much your only option, and they are not cheap!
max_gain
Thanks for that.
I have also came across a post somewhere on the net, whereby the owner had stripped his fan down to expose a faulty reistor pack which he managed to substitute with a similar value resistor.
Dont know if you guys have seen this.
Stu
Stu
TimX5
[quote="max_gain"]
Thanks for that.
Stu
I saw that and it looked abit of a faff so I bought a second hand fan of a guy on London, well recommended I've got his number if you need it .
Thanks for that.
Stu
