Panoramic roof not closing - E70 35d M
carter4716
Post by carter4716 » Mon Sep 07, 2015 8:00 pm
No matter what I do to close the sun roof the front glass panel always dips
down like its going to slide back, and wont seal flush with the rear glass panel.
Please help its driving me madImage
Re: Panoramic roof not closing - E70 35d M
Post by X5Sport » Mon Sep 07, 2015 8:11 pm
Problems with the rear section are common.  Have a look in the E53 section for tips and hints.
Unfortunately the fix does occasionally mean a new roof cassette is needed. :(
carter4716
Post by carter4716 » Mon Sep 07, 2015 8:18 pm
Thanks for the tip, I will have a scour through now. The rear glass panel is fine, the issue is when you slide the button to close, the front glass continues to slide under like its opening again. Very strange
pvr
Post by pvr » Mon Sep 07, 2015 9:33 pm
I assume out of warranty?
paddy wright
Contact:
Post by paddy wright » Mon Sep 07, 2015 9:48 pm
Had similar and had to get a new cassette carrier under warrenty- hope this is not the case as the bill would have been arind 3k.
Daily Driver - F15 30d ///M Sport
Weekend Toy- Z4 2.2i.
Gone- Fully loaded E70 3.0 DSE
535dboy
Post by 535dboy » Tue Sep 08, 2015 6:42 am
Cassette went on mine too.
Luckily I was in warranty.
One of the Main reasons I fell out with BMW aftercare/service.
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
pvr
Post by pvr » Tue Sep 08, 2015 9:06 am
It was the reason why I did not order it. I ordered it on my E53 and really liked it, but in the end was too scared to use it in case it would fail.
Lee4.8is
Post by Lee4.8is » Tue Sep 08, 2015 9:15 am
[quote="pvr"]
I liked it too on my E53 and I was shocked it kept working while I had it because they are so renowned for going wrong.
Current...E90 330i M Spt Blue/Black  2006
              640d M Spt Blue/White 2012
Previous...
Audi TTS Black 2012
E53 X5 4.8iS  Blue 2004
               E92 M3 White 2009
               E85 Z4 MR 2006
               E61 520d  2009
               E90 330d  2006
               TVR Cerbera 4.5 1998
kenniff
Post by kenniff » Tue Sep 08, 2015 5:14 pm
I liked it on my E70 and still on my f15. So far neither have gone wrong, possibly because I never actually open it  :blink:
A non- moving see through roof wouldv'e done me, been more relaible by all accounts and presumably cheaper... but no such option....
Post by X5Sport » Tue Sep 08, 2015 5:20 pm
Agreed.  I considered one for my new car but decided against it because of the issues with these panoramic roofs generally.  Perhaps all the German car makers are using a cassette from the same supplier?
535dboy
Post by 535dboy » Tue Sep 08, 2015 6:48 pm
The one on my 535 was absolutely fine
x5 not
RS has shown a few probs but not as bad!
Currently :
2012 Audi RS4 (B8)
Previously :
chuds67
Post by chuds67 » Tue Sep 08, 2015 7:09 pm
I did see a post on YouTube, where you can quite easily remove part of a bracket on the slide part of the mechanics. Where the rear part then becomes static and therefore sort of solves the problem. Hope this helps? Mark
Nat
Post by Nat » Wed Sep 09, 2015 4:47 pm
Its a knowm issue and its the reason I orderd my E70 WITHOUT  a pan roof. Sorry its happened to you. There was a you tube and a posting on the net about fixing it, but does require it to be removed to be fixed. New cassette is your only viable option unfortunately.
Sorry ........& good luck.
