Page 1 of 2
light problem
Posted: Wed Jan 19, 2011 12:25 pm
by robo
hi all this morning had in info center message ,check park lights, looked round n/s/f angel eyes not working but indicator on[not flashing]put headlights on indicator goes out as normal,could it be just the bulb in the angel eye,is there only one?and is it a special type or something i could get from a local factor as always thanks for any ideas
Re: light problem
Posted: Wed Jan 19, 2011 1:35 pm
by Turks
Hi,
Yeah the Indicator bulb comes on automatically to mark the side of the car when the side lights aren't working (angel eyes). If you get a replacement bulb everything will go back to normal.
You can get the replacements from the dealer for about a tenner or you could take the opportunity to upgrade to LED by buying some LED Markers lights from somewhere like HID's Direct. Do a search on here and you will find some information on it. IMO they look better but some people don't like the LED White.
Turks.
Re: light problem
Posted: Wed Jan 19, 2011 1:39 pm
by pvr
I had indeed the same a few weeks back, replacement very easy.
I went with the HID direct.
I have a 10% discount code if you want it.
Re: light problem
Posted: Wed Jan 19, 2011 2:39 pm
by robo
thank you gentlemen, think i will go with standard,is it a special bulb for that price? but many thanks for the offer
Re: light problem
Posted: Wed Jan 19, 2011 2:49 pm
by pvr
It is a weird bulb and fitting. I would offer you my remaining standard old one, but it is obviously used and might not be worth your while.
Re: light problem
Posted: Wed Jan 19, 2011 3:51 pm
by pvr
This is the original bulb on the left, the replacement on the right
Re: light problem
Posted: Wed Jan 19, 2011 10:39 pm
by robo
thanks all ,cannot believe the knowlegde thats out there,just going to replace with standard part for now,thanks all again
Re: light problem
Posted: Thu Jan 20, 2011 4:14 am
by Turks
No Probs...
You can split the holder and replace the bulb but way too much time and trouble to save a £5!
Turks.
Re: light problem
Posted: Fri Jan 21, 2011 5:43 pm
by nando999
Hi Guys,
My X5 cam up with the "check park light" about an hour ago, glad i found this message board. Does anyone know of a store in Birmingham where i can by the LED replacement bulb, i though i might take this opportunity to upgrade.
Thanks in advance.
Nando999
Re: light problem
Posted: Sat Jan 22, 2011 9:13 am
by Turks
I think HID's Direct is in Manchester but if I recall correct it was next day delivery anyway... I'd just get them from their website and relax at home until they come!
Turks.
Re: light problem
Posted: Sat Jan 22, 2011 1:24 pm
by robo
how do you get at the bulb for the angel eye i can see the cap forthe main beam but cant seem to see were the angel bulb is located,thanks
Re: light problem
Posted: Sat Jan 22, 2011 1:35 pm
by Turks
There is a rectangular cover on the back of the light unit with a red coloured seal (off memory). You need to remove this cover and inside you will find the bulb fitting for the angel eyes. The passenger side is quite tough to get to if I recall so start with drivers side so you have an idea what to do.
Turks.
Re: light problem
Posted: Sat Jan 22, 2011 2:04 pm
by robo
thanks turks,found bulb removed unit , bought some led bulbs of ebay but cant see how they will fit so stripped holder apart and put new bulb in ,ahh the joys of motoring!!
Re: light problem
Posted: Sat Jan 22, 2011 2:43 pm
by pvr
Good result. The HID replacements I bought were a direct replacement.
Posted: Sat Jan 22, 2011 4:18 pm
by nando999
Hi Turks, I'm an impatient person so wanted it right away. Found a place in the midlands but wanted £55 for the LED bulbs, told them where to put it and ordered it from HID Direct.
I've taken the driver side bulb out and it looks considerably smaller than the LED replacement, will it fit without modification?
Thanks,
Nando999
