light problem
robo
light problem
Post by robo » Wed Jan 19, 2011 12:25 pm
hi all this morning had in info center message ,check park lights, looked round n/s/f angel eyes not working but indicator on[not flashing]put headlights on indicator goes out as normal,could it be just the bulb in the angel eye,is there only one?and is it a special type or something i could get from a local factor as always thanks for any ideas
Turks
Contact:
Re: light problem
Post by Turks » Wed Jan 19, 2011 1:35 pm
Hi,
Yeah the Indicator bulb comes on automatically to mark the side of the car when the side lights aren't working (angel eyes). If you get a replacement bulb everything will go back to normal.
You can get the replacements from the dealer for about a tenner or you could take the opportunity to upgrade to LED by buying some LED Markers lights from somewhere like HID's Direct. Do a search on here and you will find some information on it. IMO they look better but some people don't like the LED White.
Turks.
Present:
Past:
pvr
Re: light problem
Post by pvr » Wed Jan 19, 2011 1:39 pm
I had indeed the same a few weeks back, replacement very easy.
I went with the HID direct.
I have a 10% discount code if you want it.
robo
Re: light problem
Post by robo » Wed Jan 19, 2011 2:39 pm
thank you gentlemen, think i will go with standard,is it a special bulb for that price? but many thanks for the offer
pvr
Re: light problem
Post by pvr » Wed Jan 19, 2011 2:49 pm
It is a weird bulb and fitting. I would offer you my remaining standard old one, but it is obviously used and might not be worth your while.
pvr
Re: light problem
Post by pvr » Wed Jan 19, 2011 3:51 pm
This is the original bulb on the left, the replacement on the right
robo
Re: light problem
Post by robo » Wed Jan 19, 2011 10:39 pm
thanks all ,cannot believe the knowlegde thats out there,just going to replace with standard part for now,thanks all again
Turks
Contact:
Re: light problem
Post by Turks » Thu Jan 20, 2011 4:14 am
No Probs...
You can split the holder and replace the bulb but way too much time and trouble to save a £5!
Turks.
Present:
Past:
nando999
Re: light problem
Post by nando999 » Fri Jan 21, 2011 5:43 pm
Hi Guys,
My X5 cam up with the "check park light" about an hour ago, glad i found this message board. Does anyone know of a store in Birmingham where i can by the LED replacement bulb, i though i might take this opportunity to upgrade.
Thanks in advance.
Nando999
Turks
Contact:
Re: light problem
Post by Turks » Sat Jan 22, 2011 9:13 am
I think HID's Direct is in Manchester but if I recall correct it was next day delivery anyway... I'd just get them from their website and relax at home until they come!
Turks.
Present:
Past:
robo
Re: light problem
Post by robo » Sat Jan 22, 2011 1:24 pm
how do you get at the bulb for the angel eye i can see the cap forthe main beam but cant seem to see were the angel bulb is located,thanks
Turks
Contact:
Re: light problem
Post by Turks » Sat Jan 22, 2011 1:35 pm
There is a rectangular cover on the back of the light unit with a red coloured seal (off memory). You need to remove this cover and inside you will find the bulb fitting for the angel eyes. The passenger side is quite tough to get to if I recall so start with drivers side so you have an idea what to do.
Turks.
Present:
Past:
robo
Re: light problem
Post by robo » Sat Jan 22, 2011 2:04 pm
thanks turks,found bulb removed unit , bought some led bulbs of ebay but cant see how they will fit so stripped holder apart and put new bulb in ,ahh the joys of motoring!!
pvr
Re: light problem
Post by pvr » Sat Jan 22, 2011 2:43 pm
Good result. The HID replacements I bought were a direct replacement.
nando999
Post by nando999 » Sat Jan 22, 2011 4:18 pm
Hi Turks, I'm an impatient person so wanted it right away. Found a place in the midlands but wanted £55 for the LED bulbs, told them where to put it and ordered it from HID Direct.
I've taken the driver side bulb out and it looks considerably smaller than the LED replacement, will it fit without modification?
Thanks,
Nando999
