Hi guys,
Well known issue on E53 X5's - I have read enough on here about it !!
Now it's my turn, went to open my drivers side door yesterday and handle just pulls and doesn't open the door.
While I can still get in / out the car by lowering the windows and reaching in and opening from inside.....its a pain in the a55 !
There are DIY guides on here but to be honest my skills stop at changing a bulb - If I attempt it I know I will probably do more damage - so I guess it's off to a garage to fix.
Any idea on likely cost ? Pains me that I can't do it myself and save myself a small fortune, but that's the way it is !
Cheers for any help
Ro.
Now it's my turn ! Door handle not working......
RoShamBo
steve1986
Re: Now it's my turn ! Door handle not working......
Hi,
After putting my post on i see you have had the same problem,
must be something in the air haha
not in essex are you
2006 E53 X5 Le Mans Sport Exclusive Edition
1993 E32 740i
1993 E32 740i
- exevo
Hi all,
Well that makes 3 of us with the same problem at the moment.
Must have blown up from Essex to Suffolk
[align=center]2005 X5 4.8is le mans edition
[center]gone but not forgotten.........
e39 530d
E36 m3 evolution
E21 323i
plus quite a few ol jalopies[/align]
e39 530d
E36 m3 evolution
E21 323i
RoShamBo
Ha ha ! Good to know I'm not alone right now.
How are you guys fixing yours ?
Ro.
Ro.
- iff26
if handle is not broken yet but very stiff. Remove internal door cover,fixed with 4-5 screws,cant remember exactly.disconnect window switch and remove airbag unit(if you struggle search youtube) take WD40 and aim all the moving parts,most importantly try to aim inside cable sleeve!! Put all back together,move handle 5-10 times, after couple hours it should work smoothly again! worked for me and for other 2 two lads! looking about 15-20 min job,easy breezy, good luck!!
X5 4.4is EX Carbon Black
X5-D-Sport
I have the door handle issue too, but managed to fix it with the cable tie trick - excellent, but now it seems the mechanism on the door shut end under the handle now needs tinkering with.... damned cars lol
The handle mechanism is fine, the lifter is fine.... now I gotta fiddle with the locking block...
