Page 1 of 2
EGR replace or Bypass ?
Posted: Tue Jan 18, 2011 3:37 pm
by marlin758
I have a 55 3.0D E53 - today I started her up and noticed a puff of blue smoke from the exhaust . Set off and she went into snail mode , wouldn't rev above 2000 rpm. I stopped and restarted and she was fine for the rest of the journey and return.
I checked for fault codes and it was showing P0401 which appears to be the EGR .
I am confused as to the relative merits of replacing the EGR valve or fitting an EGR bypass valve . Cost appears to be very similar.
Anyone any suggestions ?
Re: EGR replace or Bypass ?
Posted: Wed Jan 19, 2011 7:35 pm
by mccabema
Just today, I replaced my EGR valve due to a gas recirculation error being thrown up.
I had thought about putting in a bypass valve, but there is a general sense of confusion regarding the merits of doing such a thing.
In the end, I decided to trust the white coats that developed these engines in the first place and replace like with like.
The EGR does not send emissions into the manifold at all times, the valve opens and closes, and does so at times that are beneficial to the combustion process.
Or something like that !
Basically, I can't say I know enough to side with the bypass theory, and my gut says das autos know best.
Posted: Wed Jan 19, 2011 7:46 pm
by gareth82
Was it expensive to replace like for like?
Posted: Wed Jan 19, 2011 7:53 pm
by mccabema
I buy from here:
http://eshop.original-teile.de/
Cheaper than a stealer and always spot on for parts.
Think it was about €110 aprox.
Posted: Wed Jan 19, 2011 8:08 pm
by x555
+1 Same here mccabema ;)
I took my egr valve of when doing all my recent work (see manifold thread) to have a look and it was filthy inside :o .....but not knowing too much about it and wondering wether it would affect the emissions with an mot etc i just cleaned it up and replaced it.
I do know if it's taken of there will be more power and almost certainly a cleaner engine......but we do have to keep the tree hugers happy don't we :rofl:
EDIT: pics added :)
before and after and all the sh@t that came out :o
Posted: Wed Jan 19, 2011 8:19 pm
by mccabema
I tried cleaning mine too...but the fault came back again a few weeks later.
The sense I got from my research, was that there is slightly more to it than just keeping the tree huggers :D happy.
As important as this is.....opinion is divided on whether to bypass or not.
Posted: Thu Jan 20, 2011 7:03 am
by marlin758
Thanks guys .
I have decided to play safe and fit a new one
Got one from www.c3bmw.co.uk £46 inc postage
Posted: Thu Jan 20, 2011 7:44 am
by marlin758
Think I am confusing EGR and crankcase breather - approx where is the EGR situated ?
Posted: Thu Jan 20, 2011 9:07 am
by mccabema
To the right of the manifold up the front.
Remove the engine cover and you'll see it.
Posted: Thu Jan 20, 2011 9:19 am
by x555
I thought that sounded cheap for an egr valve as i'm sure there about £140 ish new.
mccabemea did you replace yours seconf hand or go with a new one?
Posted: Thu Jan 20, 2011 9:34 am
by x555
[quote=""marlin758""]Think I am confusing EGR and crankcase breather - approx where is the EGR situated ?[/quote]
#Here you go marlin.
EGR valve circled in red
Oil breather circled in blue .....well circled ish :lol: my it skills are to be improved ;)
Posted: Thu Jan 20, 2011 7:31 pm
by marlin758
Hi x555
That is brilliant - your circling skills are more than adequate ! LOL
I know where I am looking now - may as well change both while I am in there and have ordered the engine breather . Oooops
Thanks again
Posted: Mon Jan 24, 2011 9:11 am
by marlin758
Follow up - I changed the engine breather yesterday and removed the EGR Valve - there was a large carbon build up on the steel pin of the valve which would prevent it opening properly and on the wall of the body opposite the exhaust inlet was a major ridge of carbon which would hinder the air flow through the valve .
I decided to try cleaning it - sprayed it with carb cleaner - brush , soak in gunk etc , Ended up looking like new . Quick spray of WD40 and checked the valve would open ok.
The engine breather looked reasonably ok - foam filter looked a bit dirty but changed it for the new design so peace of mind at least !
Reassembled everything and it may be wishful thinking but the car definitely seems smoother at low revs and gentle acceleration.
Tried a couple of test runs and no problems / codes up to now :)
Have a 120 mile round trip to do today so that should check it out and also ensure that I retightened everything correctly. Though I do tend to check everything 3 times nowadays - once to check it , again to ensure I have tightened it and the third time because I can't remember if I checked it or not ! :roll:
Posted: Sat Feb 12, 2011 7:04 pm
by Powercat
x555 :thumbsup: :thumbsup: :thumbsup:
Thank you for this thread, a big help today when I was changing my air filter and i did the breather aswell, that EGR was full of shit :D :D :D
Posted: Sat Nov 05, 2011 4:57 pm
by fordsmith
I think EGR replace is more useful than EGR bypass. Because if your replace EGR valve than it will be brand new with your car and so new EGR valve will give you more good performance, And if you bypass the EGR valce than the same problem can occur again. So always prefer EGR replace rather to choose EGR bypass.
