LCM LightCheck Module IV
Posted: Sun Jan 16, 2011 9:13 pm
				Hi.
I have the following code:
oE LCM: Control-unit fault
I have no issues (that I know) ! Just the fault.
Up front I have a set of xenon upgrades - as in I fitted the lamps and ballast to the existing headlamp-LED halo upgrades-led lamps in the fogs and led tails.
I have load resistors and capacitors across them to prevent flickering and "Check" lights.
I did code the DRL option but when the light control is turned to the left (Auto), the halos and main beam come on.
I thought the halos came on when the DRL is active?
Any help greatly appreciated.
