Has anyone taken off their mud flaps
celica
Post by celica » Wed Jul 08, 2015 10:53 pm
My car came with mudflaps
Not a big fan of them
Problem is the plastic rubbing has marked the paint work
I just want to know if I can just take them off or will the arch line need new securings?
touring
Re: Has anyone taken off their mud flaps
Post by touring » Thu Jul 09, 2015 12:34 pm
Its easy, you remove the centre pin (3mm) in the middle od the trim studs by either pulling the pin forward (if you can get hold of it) or pushing the pin all the way through. the stud is can then be removed and the flaps are free. If you manage to pull the pins forward you can use these to fill the holes once you have removed the flaps. One word of caution, once removed you will have to clean your car more often. :))
Mark
celica
Post by celica » Fri Jul 10, 2015 11:29 pm
I don't like the rear ones
Can't see the wide track of the car
And finding it hard to keep them in a good original black finish
