Torque App Bluetooth ODB Connector? Need to review MPG post TerraClean.
jangle
Post by jangle » Thu Jun 25, 2015 9:24 am
Good Morning All,
I am trying to purchase a Bluetooth ODB connector that with work with my X5 E53 03 and the Torque application?
Has anyone had any sucess.
I ihave an aftermarket head unit and wish to pick up the MPG since a recent terraclean.
Stuart
Greydog
Re: Torque App Bluetooth ODB Connector? Need to review MPG post TerraClean.
Post by Greydog » Thu Jun 25, 2015 1:27 pm
I have an ELM327 it works well with my lap top (ubunto) and my padfone which has Torque loaded
hope this helps
jangle
Post by jangle » Thu Jun 25, 2015 2:49 pm
Greydog,
Thank you.
Where did you purchase the unit from ?
Stuart
Greydog
Post by Greydog » Thu Jun 25, 2015 4:25 pm
From Ebay about 3 years ago was about £5 if my old brain is right
jangle
Post by jangle » Thu Jun 25, 2015 9:25 pm
Yeah then this is the same unit I have purchased, it pairs with the Android unit but when you run Torque after telling it which OBD it says unable to retrieve any data.
I have since purchase a further 3 OBD connectors and only my USB with BMW Scanner work the Bluetooth seems to fail.
Any ideas where I may be going wrong?
Stuart
Greydog
Post by Greydog » Fri Jun 26, 2015 7:30 am
If your Headunit is finding and linking with the Bluetooth Dongle OK, it should be automatic if the Dongle is plugged in. Then I would look at the Torque App, has it installed correctly?
Just a thought do you have your phone connected as well? If so try it with your phone off. While your Bluetooth may register a number of devices it is a simple system cant handle simultaneous transmissions.
Dave1987
Post by Dave1987 » Mon Jul 06, 2015 8:06 am
STEP 1: Plug ELM327 Bluetooth into Car's OBD Port
STEP 2: Turn ON Car Ignition. This is one step before engine is powered.
STEP 3: Pair ELM327 Bluetooth
On your device — go to "Settings" > "Bluetooth". Connect to Bluetooth signal with name similar to these examples: OBDII, ELM327, VLink, Can OBDII, etc.
NOTE: It can take up to 30 seconds for Bluetooth signal to show.
Pair code: 1234
If above doesn't pair, then: 0000
STEP 4: Configure OBD App To Detect Bluetooth
Launch your OBD App,Go to Settings and configure it to look for Bluetooth.
STEP 5: Connect To Your Car
OBD App should now successfully connect to your vehicle.
NOTE: If OBD App still doesn't detect the Bluetooth connection — then force quit the app and launch it again. (To force quit inside Android, use "Task Manager".)
