Correct Tyre Pressures
Pyth
Post by Pyth » Wed Jun 24, 2015 4:17 pm
Hi All
I hope that this doesn’t come across as a bit stupid but I’m a little worried about the tyre pressures for my X5 (F15 40d M Sport).  The chart on the door indicates 2.2 bar (32psi) front and rear for the tyre size I have, but that seems a bit on the low side.  On the tyre pressure info label it indicates higher pressures on different tyre sizes when carrying more people (ie wife and 2 kids).    We’re off on a long road trip and I’m just concerned to makes sure I’m on the mark with them for obvious reasons.
Any help appreciated! And sorry for being a bit thick !
2014 40d M Sport
Barry-C
Re: Correct Tyre Pressures
Post by Barry-C » Wed Jun 24, 2015 7:14 pm
I would go by what BMW state on the label on the door frame (B Post ), however, and  for what it's worth, I run my F15 3.0SE at 35 front and 38 rear and  I keep it the same when towing the caravan.  :) :)
Post by X5Sport » Wed Jun 24, 2015 9:31 pm
Higher loads always mean higher pressures to prevent tyre 'squat' and overheating.
I have never run my BMWs at anything other than factory and they've been fine.
m13lky
Post by m13lky » Thu Jun 25, 2015 11:12 pm
If you search on line most people recommend running harder than the standard, I run mine around the 35 front & 38 rear & my last F15 at a year & 2 months old when I traded it in had 5.5mm left across each tyre after 12k miles, I would def run at the slightly harder pressures if you have the 20" wheels as the inside edge on the rears can easily be worn off very quickly, I would also say do the pressures every month as they do drop & again this can be expensive!
Malc
Currently
F16 M sport 40d in space grey
Vw amarok edition auto in black
Previous
F15 M sport in carbon black
F15 M sport in white
Ford Focus Rs mk1
E70 lci M sport in space grey
F10 M sport auto in space grey
F10 M sport in white
E90 lci M spo
andylel
Post by andylel » Tue Jun 30, 2015 11:59 am
If they are run flat tyres remember they are designed to run with no air at all in emergency and they do not need high pressures to keep the side walls from collapsing.  I have always run mine at the pressures on the door pillars and have never had any issues with control or with uneven wear.
