Swirl flaps
Bubbaspaarx
Swirl flaps
Post by Bubbaspaarx » Thu Jun 18, 2015 8:38 pm
Hi there. Am going to inspect my inlet manifold this weekend to see if it has swirl flaps but in the likely event it does (I have the M57N2 engine) where should I get a full kit from. Am going to get gaskets and all. On my way! PMW quoted £75ish  for this... Expensive or not? Any difference in quality from flebay?
jagr
Re: Swirl flaps
Post by jagr » Fri Jun 19, 2015 12:11 am
I fitted these to my X3 last year
http://www.ebay.co.uk/itm/6X-22MM-BMW-D ... 1086280113
No problems with them on mine.
You can order both sizes and return the size not required for refund.
2011 BMW X3 30d M Sport
Bubbaspaarx
Re: Swirl flaps
Post by Bubbaspaarx » Fri Jun 19, 2015 8:04 am
Sweet. They are local to me so I'll pick some up today. Did you change the gaskets at the same time?
jagr
Re: Swirl flaps
Post by jagr » Fri Jun 19, 2015 6:45 pm
No, once removed they looked fine on mine.
Bubbaspaarx
Re: Swirl flaps
Post by Bubbaspaarx » Fri Jun 19, 2015 6:57 pm
Cool. Went to X8R today and picked them up. Nice people gave me both sets and will return ones I don't use. Will let you know how I get on.
russ25
Re: Swirl flaps
Post by russ25 » Fri Jun 19, 2015 7:02 pm
I used these good quality and fitted easily. ebay item 390647637135 seller does several different kits.
nadia.autoparts
