Bmw x5 x3 x6 Transfer damaged by spinning actuator gear,warning to all X drivers
kkx5
Post by kkx5 » Sat Jun 13, 2015 6:11 pm
Internet "knowledge" that you can spin actuator plastic gear...
Re: Bmw x5 x3 x6 Transfer damaged by spinning actuator gear,warning to all X drivers
Post by X5Sport » Sat Jun 13, 2015 6:30 pm
Got any more details?  Which versions and how does this occur?
kkx5
Post by kkx5 » Sat Jun 13, 2015 7:09 pm
X3 e83 atc 400 all cars, does not matter what engine or gearbox;  x5 e53 atc 500 all same as x3; x5 e70 x6 e71 2007-2009 atc 700. Will put more details later.
Post by X5Sport » Sat Jun 13, 2015 7:43 pm
Looks horrendous!  Mine is an ATC450 - whatever the difference in that might actually mean though, and not in your date range which points to the pre-LCI E70 and 6-speed E71 variants perhaps?  The ATC450 went in from 09/2009 onwards.
Look forward to more details.
kkx5
Post by kkx5 » Sat Jun 13, 2015 9:34 pm
Well, pictures refers to first gen. xdrive system from 2003-2009. After that is 2gen started with atc 450 then 45L 35L etc. Different actuator motor, diff design. Internet search tells you that if you got 3 lights: abs, 4x4,  brakelight to spin plastic gear inside actuator motor or change for some carbon fibre one. From my experience and i did round 100 transfer boxes so far, plastic gear brakes when transfer box is gone. And now, when you spin or change gear that puts even more pressure on clutch pack and all other parts inside transfer box.
Riggie
Post by Riggie » Sun Jun 14, 2015 5:28 pm
Is it possible to clarify this please, as the post doesn't make any sense to me. Thanks
kkx5
Post by kkx5 » Sun Jun 14, 2015 7:37 pm
Which part doesn't make any sense for you?
Steamyrotter
Post by Steamyrotter » Mon Jun 15, 2015 1:31 pm
Finally...
Something that CANNOT happen on my car........
>:D
Riggie
Post by Riggie » Mon Jun 15, 2015 7:12 pm
[quote="kkx5"]
This bit - "Internet search tells you that if you got 3 lights: abs, 4x4,  brakelight to spin plastic gear inside actuator motor "
shadrack
Post by shadrack » Mon Jun 15, 2015 8:23 pm
[quote="Steamyrotter"]
Finally...
>:D
lmao  ;)
current: 2016 Vw Crafter
storminmike
Post by storminmike » Tue Jun 16, 2015 8:03 pm
[quote="Riggie"]
[quote="kkx5"]
:))  It does read a little like "the eagles fly at dawn" :))...sorry :-[
I think it means...Searching the Internet reveals a potential cheap fix if the following three conditions happen at the same time
Those conditions are 3 lights: abs, 4x4,  brakelight
The fix apprently is to change the rotational position of a plastic gear inside the transfer case such that worn teeth are now replaced with good teeth
OWTTE
Post by X5Sport » Tue Jun 16, 2015 8:42 pm
Ahhh.....right......well that makes all the difference...... ??? ???
So is it when you have the ABS operating, are attempting a handbrake turn and have the traction control off.....or.....?
I guess it means if you have an ABS/DSC warning and the brake fail warning at the same time?
