Post
by Steamyrotter » Thu May 21, 2015 12:07 am
Most probably the lamp failing.
Discharge lamps tend not to reignite when warm if on the way out.
Easy test is to swap lamps over and see if fault follows it.
If not then would be the ballast on its way..
