57 x5 air suspension problem any help would be very much appreciated
ccautomotivebmw
Post by ccautomotivebmw » Sat May 16, 2015 8:56 pm
Hi all new to the forum I've a 57 plate x5 3.0d se an I had two air springs blow at once an I replaced both an then it blew up over its normal height so I ised my gt1 to set ride level high an still wouldn't level out so I replaced the level sensors on the rear both sides an had the pump removed an new bearings put in an checked all is working but now I've it back together an the car will blow up an but after short period of time it's goes down again my head is melted with this I've replaced the control unit as well
pcdee
Re: 57 x5 air suspension problem any help would be very much appreciated
Post by pcdee » Wed May 20, 2015 7:53 am
Have you looked at the valve block?
X5 E70 3.0D SE
ccautomotivebmw
Post by ccautomotivebmw » Thu May 21, 2015 8:27 am
Just ordered a new pump an valve block an arrived yesterday so going to fit today to see what the out come is fingers crossed that's it sorted at long last
ccautomotivebmw
Post by ccautomotivebmw » Mon May 25, 2015 4:26 pm
Right everything is new from pump valve block air bags an level sensors even control unit this jeep is breaking my heart an my bank account took to BMW no faults so they don't know why it's doing what it's doing either
