New Owner
PhilT
New Owner
Post by PhilT » Fri May 15, 2015 9:45 am
After 6 years with my E53 X5 I'm now the proud owner of a 2011 X6 30D - Sapphire Black with Oyster leather and dark bamboo trim. I absolutely love the car but I'm glad I've got a handbook as it's pretty different to the E53  :o
I've got a couple of early questions I'm hoping someone can help me out with:
I want to upgrade the DRL's to something whiter/brighter.  As far as I can gather from old threads MTEC bulbs were the way to go - is this still the case & if so what spec/type of bulb is required?  Is it just one bulb per side accessed through the round plastic cover?
Also, I mostly do short local journeys and want to make sure the DPF doesnt get clogged.  is there a manual procedure to clean it or is it a case of taking it for a good run every so often?
Any help would be appreciated.
I'll be selling the E53 X5 private so if anyone is looking for one give me a shout.
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
PhilT
Re: New Owner
Post by PhilT » Sat May 16, 2015 5:45 pm
Anyone?
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
Re: New Owner
Post by X5Sport » Sat May 16, 2015 6:41 pm
Plug and play job.  H8 bulb.
DPF is auto controlled.  No manual 'clean' function available.  Either has to be dealer triggered or you need to do 40mph journeys with the rpm kept higher in a manual gear for at least 20 mins, preferably a bit longer.
PhilT
Re: New Owner
Post by PhilT » Sun May 17, 2015 1:56 pm
Cheers, will check out the MTEC ones if there's nothing better.
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
Mavster
Re: New Owner
Post by Mavster » Mon Jun 22, 2015 11:32 pm
My car has LUX bulbs, yes single bulb each side. Helps fitting if you have small hands or a girlfriend willing to help
PhilT
Re: New Owner
Post by PhilT » Tue Jun 23, 2015 3:02 pm
Cheers,
I tried the MTEC ones from HIDS direct and they didn't seem very bright so I got some LED ones off them and they're much better (cost a bit more though!)
And you're right about fitting - definitely need small hands!
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
