AM Signal
markhals
AM Signal
Post by markhals » Tue Apr 21, 2015 9:42 am
Only a minor issue, but the reception for any AM stations on my radio is pretty poor, and seems to be affected by the throttle - whenever I use the throttle the signal crackles worse. FM is fine, but I mostly listen to AM on my commute - any ideas?
Re: AM Signal
Post by X5Sport » Tue Apr 21, 2015 10:07 am
Suppressor fault is the most likely.  There is one in the aerial system and I think it's in the rear somewhere.  Could also be a poor connection in the aerial system - including corrosion.  I think the aerials are all on the near side rear window or in the spoiler and possibly the heated rear window.
markhals
Re: AM Signal
Post by markhals » Tue Apr 21, 2015 10:27 am
Thanks, is the location similar to the 3 series?
http://blog.bavauto.com/10056/bmw-poor- ... er-models/
Re: AM Signal
Post by X5Sport » Tue Apr 21, 2015 12:33 pm
This slide on RealOEM may help.  It appears to show approx where the parts are.
markhals
Re: AM Signal
Post by markhals » Tue Apr 21, 2015 1:34 pm
Brilliant, thanks.
