front brakes.
loxman
front brakes.
I everyone. recently replaced my front rotors {discs} and new pads but when I brake hard still sounds like worn pads on rotors, any ideas because this is baffling me.
Re: front brakes.
What pads/discs did you use? How far have you driven with them?
Did you put anti-squeal paste on?
X5-D-Sport
Re: front brakes.
Some performance pads have a Cutting-In compound on the face of new pads to bed them in better..
It may be this, if they come with this dried paste on them ?
loxman
Re: front brakes.
not driven far bit really sounds like grinding noise
loxman
Re: front brakes.
fitted mintex discs ad pads. done about 300 miles. think I try and change pads again this weekend. really baffling me.
Re: front brakes.
For info the standard OEM are Textar & Pagid. Your Mintex ones may have the grinding paste on them, hence being noisy. At 300 miles they're only just getting bedded in.
Never anthropomorphise computers. They hate that.- AVI-8
Re: front brakes.
Most folk don't know that brake pads and disks should be bed in, this requires a specific procedure which is important to lay a layer of pad material on the disk, this optimises brake performance and also should mean that the brakes operate quieter, and they'll last longer.
There's loads written about it if you google it, but here's a link which describes the procedure, basically you need to get your brakes very hot during the break in procedure.
http://www.essexparts.com/learning-cent ... ost/Bed-in
Hope this helps though a grinding noise is unusual, I presume you've not gone for the full blown race mintex pads? They're a good quality make but come in various compounds, what version of mintex did you buy?
Current
2006 X5 Le Mans Blue Sport Edition 3.0D
1991 Porsche 911 Carrera 2
