Not the end of the world but .....
Smeeagain
Post by Smeeagain » Sun Apr 12, 2015 7:08 pm
Got into the car today (E53 3.oD 2004) and noticed the handbrake even though in the on/park position had the button completely recessed (not flush with the handle but sitting back inside it).
I let the handbrake off but the button didn't pop out. Played around a bit and got it half out but not fully extended. The handbrake works and when i pull it up it ratchets fine. When I let it down/off it ratchets fine with the exception of the fully off position - it just doesn't make that last click. Presumably that last click of the ratchet and the release button are related.
Thoughts?
Smee
Re: Not the end of the world but .....
Post by X5Sport » Sun Apr 12, 2015 7:55 pm
Sounds like the spring has gone in the handle.
Smeeagain
Post by Smeeagain » Sun Apr 12, 2015 8:34 pm
repairable? easy to do?
Smee
Post by X5Sport » Sun Apr 12, 2015 9:16 pm
Dunno sorry.  Being a BMW they would prefer a new one be bought, but it went together so it ought to be fixable. Have a look at RealOEM an see if it comes to bits, or if there are any on line video guides etc.
This page shows what looks like a spring in the middle of the assembly, but I suspect there may be another in the handle itself which needs the handle pulling off.  Looking at piccies on line I cannot see how you can get inside the handle itself.  It looks like a tube which houses a spring and rod with the button on the end and everything pressed into place.
Smeeagain
Post by Smeeagain » Mon Apr 13, 2015 8:32 am
ok, so I understand the spring in a tube in the handle, but what about the last click of the ratchet (on the way down) not clicking - surely that is separate and therefore either something else?
Smee
Post by X5Sport » Mon Apr 13, 2015 8:56 am
All
I can think is that somehow the button issue may be causing some sort of fouling?  Until you have it apart it's hard to make an exact diagnosis.  It could be the main spring is broken and causing fouling?
Smeeagain
Post by Smeeagain » Mon Apr 13, 2015 8:03 pm
Indeed - anyone know how to remove the handle ......?
Smee
shadrack
Post by shadrack » Mon Apr 13, 2015 8:36 pm
could be un related by on my first x5 2001 the little notches on the hadbrake (abit like cog teeth) wore out the last 2, i re filed them in with a tiny file to fix
current: 2016 Vw Crafter
Smeeagain
Post by Smeeagain » Wed Apr 15, 2015 10:37 pm
So how did you access the cog teeth?
shadrack
Post by shadrack » Wed Apr 15, 2015 10:42 pm
removed all the trim from round the handbrake and it was visable
shadrack
and centre console
Smeeagain
Post by Smeeagain » Thu Apr 16, 2015 9:17 am
And if I recall correctly centre console removal is not a five minute job .......?
