Battery replacement with a LPG tank?
swipe
Post by swipe » Fri Jan 14, 2011 2:30 pm
Guys need some help think I need to change the battery on my 4.4, but as it has the a LPG donut tank fitted not to sure if I can safely move the tank to get the battery. :?
Has anybody had an experience getting the battery out?
Sanj
Re: Battery replacement with a LPG tank?
Post by Sanj » Fri Jan 14, 2011 3:18 pm
PM LezMTaylor - he has the same model and LPG tank fitted.
swipe
Post by swipe » Fri Jan 14, 2011 5:43 pm
Cheers Sanj
lezmtaylor
Post by lezmtaylor » Sat Jan 15, 2011 12:30 pm
If the tank is fitted with flexible pipes, you can release the securing bolts and lift tank up and block it( DO ENSURE NO LPG IN TANK-- it is bl--dy heavy with lpg in it).
Then should be enough room to change.
Also DO NOT shut tailgate with battery disconnected, you will not be able to open it !!!!!!!!!!!!!!
If you have solid pipewalls they have to be disconnected before lifting tank and it is a pitta of a job.
As an idea , my car had solids and I did not know and cracked one lifting without undoing, have since fitted flexies, cost about £100 inc labour.
Lez
swipe
Post by swipe » Sun Jan 16, 2011 9:43 am
Cheers Lez think my tank has the flexi pipe fited, did make the mistake of trying to lift the tank but the remembered that we filled it up 3 days ago.
Now will have to wait till the tank is empty to remove that battery.
