Have bought an x5 back in december. engine was burning oil and a misfire on cylinder 1 and 2. bought and fitted a recon engine and the misfire on 1 and 2 is still there with lilt to no power at all from the engine... changed plugs and coils around and the fault is still there. change the injectors around as well just in case but the fault remains.
Any ideas guys ???
Kevin
Helppppp
- Steamyrotter
Re: Helppppp
I'd say check the wiring harness first.
You could use a spare injector and coil pack to test that.
Any error codes??
Any error codes??
Re: Helppppp
Do the coils have to be recoded if they've been changed?
If so & you haven't done this it could be your problem!
Re: Helppppp
[quote="subsea"]
Any ideas guys ???
Kevin
I'm not really answering your question but why did you buy a recon engine??
Any ideas guys ???
Kevin
