Hi everyone,
long standing problem but dearly looking for help and advice wherever possible.!!!
Bought a 2004 N62 44i X5 nice looking car but with a major engine problem as in burning oil... and a misfire on cylinders 1 and 2. bought a recon engine (thats another story) and had that fitted. cylinder 1 and 2 are still misfiring ?
changed plugs and moved coils around to see if the misfire would migrate but nope, it stays with 1 and 2..
i even changed the injectors around to see if it was that and no, the misfire is still with cylinder 1 and 2
HELPPPPPPPPPPPPP !!!!!
Regards
Kevin
n62 4.4i misfire
Re: n62 4.4i misfire
I've got the same problem which I'm hoping is the valve cover gaskget, but as you've changed the engine I cant be of much help!
Would you mind me asking roughly how much you found a recon engine for incase I get further problems?
I paid 3400 for the engine on mine.
rgds
Kevin
rgds
Kevin
Oh thanks, not outragous I suppose for an engine of its size. My friend has just paid 3200 for a 2L diesel 3 series reconditioned engine.
If I replace that I doubt there are any origional parts left! Good luck finding your problem.
Have you checked the valvetronic ? the variable camshaft are noted amongst high milers for failure. ?
check for any air intakes, burst or cracked pipes as that will also cause the misfire.. is yours multiple ?
