Page 1 of 2
Pictures chopped, off centre !
Posted: Thu Jan 13, 2011 8:35 pm
by Bungie
I have noticed pictures are off centre including mine resulting in the right hand side being chopped off, Why !
Re: Pictures chopped, off centre !
Posted: Thu Jan 13, 2011 8:41 pm
by pvr
Yes, noticed the same.
The only way around I found was to reduce the picture size first before posting.
Posted: Thu Jan 13, 2011 8:56 pm
by Bungie
I did reduce mine to 800 x 600 shot in 4.3.
Posted: Thu Jan 13, 2011 8:57 pm
by pvr
Ok - will discuss with the tech side to see what can be changed.
Posted: Thu Jan 13, 2011 9:01 pm
by Sanj
This happens to me when viewing on the iPhone. OK otherwise - are you having these problems on the laptop/desktop too?
Posted: Thu Jan 13, 2011 9:09 pm
by Bungie
I'll go and fire up the desktop widescreen. I am on and normally use laptop 4.3.
Back in 5
Posted: Thu Jan 13, 2011 9:21 pm
by Bungie
Ok, the pictures are fine on the desktop 16.9 and other laptop 16.9 but on a 4.3 display there chopped and i know mine were shot in 4.3.
Posted: Thu Jan 13, 2011 9:30 pm
Cropped on the iPad too, but PC is fine. I need em to do the air filter & breather if I can and the questions in the How to get answered :poke: :D
Then I can prop the iPad under the bonnet and get it filthy................. :oops:
Posted: Thu Jan 13, 2011 9:35 pm
by Bungie
Is your pc widescreen 16.9 or normal 4.3.
Posted: Thu Jan 13, 2011 10:08 pm
Both PCs use 16:10 format. So both are widescreen and one is for photo editing so its a 2560 x 1610 system. Browsers are Firefox current version in all cases except iPad which is limited to Safari :headbang: PC OS is either XP SP3 or Vista SP1 - all 32bit, to be migrated to Win7 64 bit when funds permit.
Posted: Fri Jan 14, 2011 12:03 am
by ChewingBacca
Any of you increased the browser zoom level?
This is the only time I get that problem.
Firefox users can install Nosquint to sort it out if necessary.
Posted: Fri Jan 14, 2011 12:10 am
by x555
[quote=""X5Sport""]Cropped on the iPad too, but PC is fine. I need em to do the air filter & breather if I can and the questions in the How to get answered :poke: :D
Then I can prop the iPad under the bonnet and get it filthy................. :oops:[/quote]
Answered now :P .... would have responded earlier fella but i've been a little busy on mine.......but thats for another thread!
Posted: Fri Jan 14, 2011 11:13 am
by pvr
Jim has mentioned that a fix might be possible. Will keep you posted on this one.
Posted: Sat Jan 15, 2011 12:59 pm
by sp3ctre
This should be sorted now...
Incidentally, I am going to upgrade the forum software this afternoon, so if you see it go offline for a short while don't panic :)
Posted: Sat Jan 15, 2011 4:42 pm
by Bungie
Nice one :D I can see full pic's :thumbsup:
All good for xdrivers.co.uk and well done for a quick fix.
