Can someone check their navigation system for the following post code ...
pvr
Post by pvr » Tue Mar 17, 2015 4:44 pm
For the E70, can someone tell me if the following post codes exist on their system and what navigation release they have:
RG20 0NU
RG45 7PU
Thanks  8)
pvr
Re: Can someone check their navigation system for the following post code ...
Post by pvr » Thu Mar 19, 2015 8:35 pm
Anyone? :'(
Post by X5Sport » Thu Mar 19, 2015 10:26 pm
I can check 2moro if that helps?
I've got the 2014 OEM data.
pvr
Post by pvr » Thu Mar 19, 2015 10:27 pm
Perfect, please.
Post by X5Sport » Fri Mar 20, 2015 8:17 am
[quote="pvr"]
RG20 0NU
RG45 7PU
Thanks  8)
Ball Hill, Newbury for the first one.
Wellington College, Crowthorne for the 2nd.
Any good?
pvr
Post by pvr » Fri Mar 20, 2015 9:23 am
It allowed you to enter it fully?
Post by X5Sport » Fri Mar 20, 2015 9:30 am
Yessir
pvr
Post by pvr » Fri Mar 20, 2015 9:34 am
Gracia
Post by X5Sport » Fri Mar 20, 2015 9:38 am
De nada.  :)
dobbor1
Post by dobbor1 » Fri Mar 20, 2015 9:57 am
Richard, how easy is it to upgrade from 2011 to 2014 maps?
Currently:  2011 E70 X5 40D M Sport Black Sapphire
Post by X5Sport » Fri Mar 20, 2015 10:36 am
Very easy.  It takes several hours.  You have to get a map set from BMW (3 DVDs @ £25) and a licence key - that's the expensive bit @ £180! - and then load them one at a time.  If you are going to load them in one go you need to connect the car to a decent charger or you get a flat battery in about 30 mins, and the loading takes 2-3 hours and you have to keep waking the car up every 15 minutes or so!
Once loaded, the system then configures the new database whilst retaining the old one so you can still use the car.  The database takes several hours to sort itself out and then the CIC reboots and away you go.  This is why there is an 85GB hard drive of which only a few GB are available for music etc.  The rest is to allow the mapping system to sort itself out and run two copies during the update process.
You can update the DVDs whilst driving too, but it still takes 2-3 hours which is why I did mine at home with a 10A charger connected.
Or you can get the Dealer to do it for an extra £100 labour!! >:(
dobbor1
Post by dobbor1 » Fri Mar 20, 2015 11:33 am
Nice one thanks Richard. PM received also.
Mpower
Post by Mpower » Fri Mar 20, 2015 11:35 am
Theres the glovebox usb method to update maps which is much quicker also using 3 USB  and the end you input the license key to activate.
dobbor1
Post by dobbor1 » Fri Mar 20, 2015 11:12 pm
I assume I can also use Micro SD Cards using a USB adaptor or does it have to be actual USB sticks?
Mpower
Post by Mpower » Sat Mar 21, 2015 8:21 am
Never tried micro sd but one with standard sd with usb adapter worked fine,wouldnt see why not.
