Battery Reset Procedure
Posted: Fri Mar 06, 2015 7:35 pm
Interesting issue.... and suggestion / comment from Cotswold BMW....
I had spurious dash warnings & stuff happen due to low voltage battery...
And one of these was.... on low bean + front fogs.... then using Main beam...
The fogs went out, all the lights momentarilly quit (1 second) and then main come on...
And the fogs stay off unless switched on again... then suspension warnings in cluster displayed..
I had a 1000 CrankAmp battery fitted... and expected these issues to quit...
BUT.....
I understand from Cotswolds that the drop out of the lighting was to ensure the computer was not starved of power or essential systems etc, so unnecessary loads would be dumped ie fog lamps...
The car learns it has a sick battery & therefore ensures it can keep critical systems alive...
I now have to some how tell it that it has a new battery....
Wonderng how that is done ?
On ftting the NEW battery, i kwpt the systems allive by using a second battery hookwd to the JumpStart connectors under the bonnet... and wondering if I either need some diagnostc skills plugged into the OBD port or simply disconnect the battery totally for 20 mins & maybe the car will learn it has a new cell fitted ?
Any ideas on ths one ?
BUT.....
