Replacing Rear Differential Bearings
X5-D-Sport
Post by X5-D-Sport » Wed Mar 04, 2015 11:15 pm
Have a Rear Diff thats whining a bit... not got any worse over 15k miles...
Towed a heavy vehicle for 15 miles... a bit much for my X5 it seems.....
So, I can remove my rear diff in 45 minutes easily..
BUT how difficult is it to replace the bearings, as I have a hydraulic press & puller.
As the shimming is ok and has been for 140,000 miles, surely its just a case of stripping it & a rebuild ?
GB
X5-D-Sport
Re: Replacing Rear Differential Bearings
Post by X5-D-Sport » Thu Mar 05, 2015 1:40 pm
Surely some one has done this ?
Greydog
Post by Greydog » Thu Mar 05, 2015 5:02 pm
Hi Grant
I have just had the rear diff fail on my 4.6 the BMW specialist I use was going to rebuild it but as I have a warranty they decided new diff from BMW??? Just spoke my specialist who said look at www.bearing kits .co.uk
Apparently they do complete X5 Bearing kits
X5-D-Sport
Post by X5-D-Sport » Thu Mar 05, 2015 7:10 pm
Many thanks - will look..
Regards
Grant B
X5-D-Sport
Post by X5-D-Sport » Fri Mar 06, 2015 11:40 am
Well,
I looked up the ££ price of a bearing set for this diff job.... £260...
They're having a laugh !
I am hoping to fid the bearing sizes & get some hardened bearings from a supplier, should be about £15 per bearing + the outer oil seals... so, I should be able to do the job for approx. £80 + 2 hrs to do the job all up..
Much simpler than originally thought.
So... next question...
Any one know where to get the bearing size measurements ?
briankerrys47
Post by briankerrys47 » Fri Mar 06, 2015 1:22 pm
Well,
[/quote]Unless Richard,Raj,Sanji have answer the no/make  is stamped on bearing meaning you have to dismantle first  :o :o
sprintman
Post by sprintman » Mon Mar 16, 2015 10:13 pm
A friend of mine had his diff fail last year-Diff is made by DANA but will not supply parts due to contractural agreement with BMW, bearings specially  made for BMW- my local bearing supplier found a source BUT was very expensive(£65 +vat per bearing) in the end got a diff from ebay for £280 ish and was ok, did find some companies  willing to rebuild but again was very sketchy on price-£250 min still have his old diff if you want any bits!!
My other car is the wife's mini dooper( it must be mine all she does is drive it!)
X5-D-Sport
Post by X5-D-Sport » Wed Mar 18, 2015 12:52 am
I did read of one guy who discovered that the inner & outer bearing cages are Metric & imperial respectively...
And this chap bought both bearing sets, matched up the cages and fabbo  !..
Cost a fraction of the £70 per bearing... whivh we know are only worth £10 per bearing...
I will probably buy a complete used item, strip it & see whats out there to get the bearings at under £20 for each of the 4 bearings if I can..
We will soon see I guess
