Well was something like that, started the car it came on then switched it off then started it again and it and no message, any advice because I got a fright and hope its nothing too serious eventhough it sounds like it !!
tubs
Warning Message on dash:STOP! Oil pressure low !
tubs
- Sanj
Re: Warning Message on dash:STOP! Oil pressure low !
Tubs,
Have you had a chance t check oil levels too? Weren't going round a corner on rails at the time of the message were you!
tubs
Sanj,
Was parked on a slope when I started the car, going to check oil levels in the Morning
- Sanj
That'll probably be it mate - but check oil level...
- Turks
- Contact:
Was the engine cold when you started it? It could have been a combination of the oil being cold (less viscous) and being on the slope. Check the oil level and also check for any leaks under the car. Hopefully it is nothing.
I can't remember if the Oil pump is Mechanical or Electrical but I imagine the pressure sensor is along the lines after this.
Turks.
Turks.
Present:
Past:
Past:
