Shifter in M/S doesn't spring back to Park when P pressed?
Anyone else have this ?
Re: Shifter in M/S doesn't spring back to Park when P pressed?
[quote="celica"]
Hmm mine works fine with a single click of the P button
Agree, Hmmm! Car stopped, foot on the brake or handbrake on?
Also, does it jump to park from D or R when the engine is switched off?
Can't help any more I'm sorry to say.
No it stays in Park but doesn't spring back right ![Sad :(](./images/smilies/sad.gif)
Get the fault codes read. Sounds like it could be the gear selector control box going by your other posts too.
People buy horsepower but drive torque!
I have seen this a few times at work it is normally a gear selector switch, I would agree with getting the faults checked to be safe. Hope this helps
03 carbon black edition 4.6is, champagne leather, sunroof, 20" 5 spoke, DSP
Suspected gear selector
Although looking at realoem and Indy flagging up it would be a replacement gear selector
Is there a replaceable switch?
If my understanding is correct the 'switch' is in the control box attached to the bottom of the gear selector so you end up with a whole new unit.
Looking at diagram it looks like whole new unit
