replacing the Battery....
Posted: Wed Feb 04, 2015 12:34 am
by X5-D-Sport
Hi Gents / Ladies,
After reading many interesting Battery issues here,
Not checked my voltages recently, but having some interesting symptoms...
Firstly,
When swapping out to a new battery, is there a need to keep the computer powered up to preserve settings & memories, such as seat positions, auto wind up on the window switches etc....
I found a 900 Crank Amp unit Halfords are doing with a 3 yr warrantee for £120...!!
Any better deals out there ??
Secondly,
Thinking I got voltage issues, because,
If I have my Front Fog lights on + dip beams, often when engaging main beam, momentarilly all the lights bail out for a second, the mains come on & the fogs are cancelled...untill I switch them back onnatbthe switch....
At the same time the fogs are cancelled and bail out, some thing tells the light clusters to point the motors that alter the positioning right down very low (momentarilly) - far lower than the trimmer roller switch on the light controlls can ever do...
And imediately after a Suspn Self Level Inactive warning pops up also...
Starting the car on the coldest mornings so far is perfect - instant starts... so the Amps are reaching the starter... just wondering if the lighting issues are symptoms of the battery voltages getting low causing the lighting & computer warnings ?
Opinions & thoughts on this one welcome plz.
Regards to all.
Grant B
Re: replacing the Battery....
Posted: Wed Feb 04, 2015 7:30 am
by IanT
Hi,
I have just replaced the battery in my our X5 with this one from Halfords
http://www.halfords.com/motoring/bulbs-wiper-blades-batteries/batteries/yuasa-12v-silver-car-battery-hsb019-5-yr-guarantee
As you see, it is same spec and price as the one you mention but has a 5 year warranty.
The car was new to us at that point (and the seller paid for the battery) so I did not worry about computer settings, so sorry I cant help with that. However, the battery has performed very well in the past two weeks use.
Ian
Posted: Wed Feb 04, 2015 8:37 am
by omodos
hi there alas cant help with the errors you get on suspeniosn etc , but from experience of removing replacing my battery quite a few times this month the only thing I lost was the unlocked obc settings....ie they get locked again and you have to unlock if you want....the radio settings retained, but list time date, and no affect on steering wheel seat position etc.......
