Removing Rear Airvents
noxid1969
Post by noxid1969 » Sat Jan 31, 2015 3:42 pm
I have just spent the last hour trying to remove the rear airvents but with no success, the fasteners are hidden behind the carpet that lines the transmission tunnel. Does anyone know how this comes off or is there an easier way to remove the vents. I am trying to add back the direction adjusters which have been kicked off by little feet in the back.
Any assistance appreciated!
tristan
Re: Removing Rear Airvents
Post by tristan » Sat Feb 14, 2015 7:53 pm
Have you managed to sort this? Mine have suffered the same treatment...
Steamyrotter
Post by Steamyrotter » Sat Feb 14, 2015 11:51 pm
Open the centre console and pull out the tray.
There are 2 screws on the top pointing backwards.
Remove those and then the vents will push out.
Putting back requires a little fiddling to get it inside the pipe but the best way is be gentle.
tristan
Post by tristan » Sun Feb 15, 2015 5:20 am
Top man, much appreciated
Steamyrotter
Post by Steamyrotter » Sun Feb 15, 2015 2:58 pm
Took me hours the first time looking for screws and how to get the tray out..
I was a bit miffed when it turned out so easy!!!
You need tray out so its easier to line it up with the pipe.
noxid1969
Post by noxid1969 » Tue Feb 17, 2015 10:04 am
Thank you so much, will try later!
noxid1969
Post by noxid1969 » Sun Feb 22, 2015 11:58 am
Has anyone got a photo of the screws, nothing seems to come out in the centre console and I can't see what I am supposed to be undoing as the console seems one piece of plastic.
Help!
